Which soldering tips are needed for most jobs?
BaronKyle
  • The more I see, the less I know for sure.
« on: 5 Dec 2015, 07:57 pm »
I was going to start with the conical pencil tip.  What are the others used for?
electricbear
Re: Which soldering tips are needed for most jobs?
« Reply #1 on: 5 Dec 2015, 08:14 pm »
The best soldering tip is to have Mike Missel or Jeff Jackson do it.
Bob in St. Louis
« Reply #2 on: 5 Dec 2015, 08:18 pm »
Assuming you're talking about finer electronics, light electrical work....(like soldering crossovers)????
ST4 looks like something used for radiator repair or maybe stained glass work (although I've never done stained glass).
The ones I use for electronics look like ST5 and ST6.
thunderbrick
  • I'm just not right!
« Reply #3 on: 5 Dec 2015, 09:40 pm »
Yeah.  Take it to them now, or take it to them later.  :banghead:
Folsom
« Reply #4 on: 5 Dec 2015, 10:54 pm »
Different applications have different needs, but in general the smaller the better for most electronic stuff.
When you doing binding posts however a big fat-ass-tip is great.
vintage9594
« Reply #5 on: 6 Dec 2015, 01:31 am »
I second the Mike Missel recommendation....
BaronKyle
« Reply #6 on: 6 Dec 2015, 04:12 am »
I use the references above for anything serious.  However I'm also learning to solder.
Next step is to practice on some scrap boards.
Then eventually I'll cross off doing a kit build from my bucket list.
My wife likes this bucket list, much better than Austin Power's version.
Bob in St. Louis
« Reply #7 on: 6 Dec 2015, 04:28 am »
I taught my daughter to solder. In fact, she soldered the crossover networks for her own speakers.
There's a thread complete with pictures and everything. So, if she can do it, you can do it.
She was 9 at the time. The speakers work great to this very day.
http://www.audiocircle.com/index.php?topic=121505.0
So....what are you waiting for?  :wink:
