Custom Cables Available from Triode Wire Labs
0 Members and 6 Guests are viewing this topic. Read 88831 times.
SoCalWJS
Re: Custom Cables Available from Triode Wire Labs
« Reply #20 on: 31 Jul 2021, 05:57 pm »
Another custom cable, this time for a LG OLED CX48 flat screen TV... It's pretty amazing on how the picture improves so much with a better power cord on it!
Pete
Looks nice! Might have to look into something like that. I have the LG OLED CX77 - don’t know if it’d the same termination or not. Pretty sure it’s a 90 degree connection so that it can be flush mounted.
Triode Pete
« Reply #21 on: 7 Aug 2021, 12:32 am »
Hey John,
Here's the initial feedback from my customer with the LG flatscreen TWL cord upgrade...
"Hi Pete,
Got the custom cable installed on the TV yesterday...  A bit of a tight squeeze -- the cord has to bend sharp right to avoid mounting point for access cover.  There's probably a little stress on the junction between the connector and cable -- but it felt solid.
Immediately noticed a vibrancy to the reds after turning the TV back on and cycling through different channels (almost fluorescent in the color pop).  Sound quality also seems improved -- bass better and sibilance diminished.
It looks like LG uses that same crappy cable all the way up the line.  I don't get why, with their economy of scale, they can't provide something better.
Thanks for the quick turnaround too!"
Pete
Triode Pete
« Reply #22 on: 16 Aug 2021, 05:53 pm »
This time a set of special speaker cable jumpers for a horn system in Singapore....
These have Premium Cardas CAB bananas leading to super high quality gold-plated over solid copper angled pin connectors. 100% made in USA components.
Pete
Triode Pete
« Reply #23 on: 26 Oct 2021, 05:08 pm »
Another set of custom cables, this time a pair of XLR Y-Adapters. Single female XLR to two male XLR connectors.
Pete
Triode Pete
« Reply #24 on: 27 Oct 2021, 08:47 pm »
Another custom cable! A Y-umbilical cable to run from a Jeff Rowland Design Group PC-1 to provide power to two Jeff Rowand Model 201 mono amps. The Jeff Rowland PC-1 is an advanced external power rectifier and conditioner based on the same Active Power Factor Correction (PFC) technology incorporated in JRDG reference amplifiers.
This Y-adapter cable features a high quality C14 IEC male connector to two high quality NEMA 5-20 female connectors.
Pete
Triode Pete
« Reply #25 on: 28 Oct 2021, 01:59 pm »
Another custom cord for a "Power Supply Umbilical Cable for Modwright Instruments" -  PH 9.0 Phono Stage
Pete
Triode Pete
« Reply #26 on: 16 Dec 2021, 09:38 pm »
This time a custom "Obsession Ag NCF" power cord, for a customer who wanted silver plating instead of rhodium plating. I used the custom-ordered Furutech FI-48 NCF Ag series of connectors!
Pete
rpf
« Reply #27 on: 17 Dec 2021, 02:04 am »
Beautiful!     :thumb:
Cheytak.408
« Reply #28 on: 17 Dec 2021, 06:57 am »
Pete
Sweet!  Damn, you do great work!  :thumb:
Triode Pete
« Reply #29 on: 18 Dec 2021, 08:20 pm »
Thank you kindly!
Triode Pete
« Reply #30 on: 7 Jul 2022, 12:20 am »
This time for a repeat customer who just purchased a dCS stack and needed a very flexible XLR cable to bend quickly to a right angle.
I used the great sounding, premium Cardas CG FXLR and CG MXLR XLR connectors in this custom application.
Pete
Cheytak.408
« Reply #31 on: 7 Jul 2022, 04:51 am »
As always, nicely done!  :thumb:
richidoo
« Reply #32 on: 7 Jul 2022, 05:48 pm »
He’s gonna turn the stack around backwards to show off the pretty cabling! 🤩
Triode Pete
« Reply #33 on: 18 Jul 2022, 04:57 pm »
Here's some power cables that needed a right angle (90 degree) IEC connection... I have the Wattgate right angle connector bodies in-stock, available on all TWL power cable products!
Pete
rollo
  • Rollo Audio Consulting -
« Reply #34 on: 18 Jul 2022, 07:50 pm »
One cannot go wrong with TWL.
charles
Triode Pete
« Reply #35 on: 18 Nov 2022, 08:59 pm »
This time, for me, a little R&D, trying some different material specs...
Into my high power audiodharma Cable Cooker it goes!
Pete
Triode Pete
« Reply #36 on: 11 Jan 2023, 08:17 pm »
A trio of Digital American power cords fitted with NEMA 5-15R female connectors. These will be used to plug in audio-related "Wall Warts".
Pete
Big Red Machine
« Reply #37 on: 12 Jan 2023, 01:48 am »
What would you need to get for a 27 foot power cable to my amp? I'm shopping different cable makers.
Triode Pete
« Reply #38 on: 12 Jan 2023, 04:09 pm »
PM sent...
Triode Pete
« Reply #39 on: 13 Jan 2023, 11:15 pm »
This time a large set (7 pairs!) of custom speaker driver cables for a high-end horn system.
Two, 1m pairs  – Crossover to Woofers
Two, 2m pairs  – Crossover to Midrange Drivers
Two, 2m pairs  – Crossover to Tweeters
One, 1m pair  – Tweeter to Tweeter
Pete
