Best vintage receiver with phono input for $200 or less
0 Members and 1 Guest are viewing this topic. Read 18363 times.
S Clark
Re: Best vintage receiver with phono input for $200 or less
« Reply #20 on: 9 Dec 2015, 10:39 pm »
Be aware that your receiver vents heat from the upper rear of it's case- which you have covered with your turntable.  I suggest you raise the turntable with some spacers to allow better flow of air to assist cooling.
srb
« Reply #21 on: 9 Dec 2015, 10:46 pm »
Absolutely.  Cost-effective spacers I have used are two or three hockey pucks (~ 2" - 3") on all four corners.
http://www.sportsauthority.com/A-R-PuckPack-12-Pucks/product.jsp?productId=11544805&cp=694247&parentPage=family
ACHiPo
« Reply #22 on: 10 Dec 2015, 06:36 am »
Getting your speakers off the stand with the turntable should help phono quality tremendously.
Sparky14
« Reply #23 on: 10 Dec 2015, 04:26 pm »
I just picked up a Luxman R-113 receiver for under $100 shipped. Even at just 30-35 wpc, this thing puts out a lot of quality volume. There are higher power options as well (R-115 and R-117).
Unfortunately, I gave up vinyl long ago, so no feedback on the phono input.
RDavidson
« Reply #24 on: 10 Dec 2015, 05:34 pm »
Yup. More often than not, I think we tend to over estimate how much power we need for normal listening volumes. As long as the amp has a stout power supply and sturdy output devices (as most good classic receivers and amps do) you'd be surprised how far a solid 20 wpc can get you. I think many of these lower power amps can sound better than their behemoth brothers with relatively efficient speakers too.
pinkfloyd4ever
« Reply #25 on: 16 Dec 2015, 03:03 pm »
So I got some hockey pucks to prop up the turntable and allow more ventilation. WAF of hockey pucks was low but I still convinced her to let me keep them there when I explained it could shorten the life of the receiver if it wasn’t getting adequate ventilation.
WAF of speaker stands was -10/100, so those are a no go for now. Maybe I can find some mid-century plant stands that will hold the speakers and also match that cabinet the receiver and TT sit on. We mostly listen at low to medium volume though and I think the hit in phono sound quality is minimal at lower volumes. I’m going to try to tell a difference with them on some temporary cardboard boxes or stools when she’s not home.
All I know is the new Adele 25 album I got for her sounds amazing on vinyl with this new cart.
srb
« Reply #26 on: 16 Dec 2015, 03:09 pm »
I thought they looked OK, maybe even a little bit high-tech - at least compared to those industrial cork/corrugated rubber laminated vibration pads.
Maybe if she wasn't aware what they actually are .....  ;)
