0 Members and 1 Guest are viewing this topic. Read 6539 times.
Hey.The only bad thing about make an offer is if they accept and you end up not wanting or something happens and you don't but they can leave you legit bad feedback. I think if you read the make an offer rules you are entering into a contact sort of.Good luck
Looking for genuine/quality cable, both patch and bulk. I'm not looking for anything marketed at audiophiles. Cables will be used for routers, AP points, etc.Why am I asking? I read an article on arstechnica.com that shows many cables don't live up to cat6 (or even 5e) spec. Testing was done by bluejeanscable. I could just buy bluejeanscable but I'd like to look at others.
Belden is a good cable brand. As for where to buy? You should be able to buy in bulk locally in your area. And there is a good chance at wholesale. As for name brand manufactures of CAT6 or CAT6a not meeting spec I would strongly disagree. The problem is not the twisted 4 pair cable whether shielded or non shielded but rather how the cable is installed, terminated, were the correct ends used, there in were CAT 6 ends used or were CAT 5e used, and what brand, manufacture of ends were used. I prefer Panduit manufacture/brand. Here is a thread from earlier this year that may help. http://forum.audiogon.com/cgi-bin/fr.pl?htech&1421239386&openusid&zzAnixterhttps://www.anixter.com/en_us.html
Guy'sJust to clear some things up. Patch cable is a cable that you move all the time. like one that you connect to your work computer that you move around alot and then disconnect it wrap it up stick it in your bag or in a data center where you have a patch field and your moving data around through the patch field to different ports. The patch cable are almost always made of stranded cable because stranded cable does not break as easy at the point of termination. As for solid cable that should be almost always if not always punched down not crimped. You can crimp it but you better make sure the rj45 plug is one for solid cable and that the one for stranded cable is for stranded cable. Solid core cable that is terminated with a rj45 plug even if its a cat6 plug almost never really makes spec. it may at fist but when you start to move it around a lot it will not soon after that.Solid core cable really is for in wall perminnate installs and for cables that will not be moved. Usually everything outside the walls and stuff that gets moved around should be stranded.The other thing is make sure any cable you buy is PURE Copper not CCA. CCA is now illegal. I have had luck with vendor as he sells quality stuff. http://www.ebay.com/itm/CAT6E-CMR-Ethernet-Cable-White-1000FT-NO-SPLINE-550MHz-23-AWG-Copper-NOT-CCA-/121743833825?hash=item1c587f7ae1I know a lot of people know this but i figured i clear some things up in case they didn't.Hope this helps.
Since on the subject of cabling and terminations, I'm curious about opinions on the EZ RJ45 system vs. conventional type. Opinions appreciated.
I've seen them, but not used them. Do the EZ Cat6 plugs have two rows of staggered wire channels as opposed to a single row as in Cat5 connectors? If not, they may not pass certification. I only have a tester that checks continuity, shorts, reversed pairs, etc., not a performance analyzer, so the actual performance aspect is always an unknown.I had also read about some random shorting on the exposed wire ends, but I'm not sure what kind of jack configuration would allow this to happen.Steve
Here's the article. Please, please, please don't turn this thread into an audio/audiophile one. Lets keep it IT.http://arstechnica.com/gadgets/2015/07/340-audiophile-ethernet-cable-gets-a-marginal-pass-on-the-test-bench/Denke's comment on Cable Matters cable from Amazon (Denke is from bluejeanscable )"This is quite typical of Chinese Cat 6 that we see, most of which does not pass 5e," elaborated Denke. "We find that the fault is almost always in the cable, rather than the terminations—if we re-terminate the cable we generally get little or no improvement."Note that this is the opposite of jea48 statement. Now I'm not saying either is right/wrong, but to me seems like we cannot generalize.According to the bluejeanscable site, the test every cable before it leaves. Maybe I'll pay a premium and stick with them, it's not like I'm wiring up a high rise office.
Agree.And just to add don't mix categories. If the in wall cabling is CAT6 use CAT6 connectors, patch panel, and patch cables/cords. Also do not buy patch cords any longer than you need. Long patch cords that are way longer than is needed and then coiled in a small radius coil can cause errors. Same goes for in wall cabling. Do not tightly coil up excess cable at the wall jack end or the patch panel end.Keep patch cords up off the floor so they can not be walked on. Just walking on the cable can cause the lay of the twisted pairs to change.
I'm wondering what would the net effect be of having, say, cat6 cabling and infrastructure and then using a cat5e rated patch cable. I assume that would limit potential for attached device, but would it have some effect on entire network?
You must never mix Cat5 and Cat6 cables on the same network. The network speed will be limited by the lowest grade of cable installed within it. Therefore, if you outfit your network using Category 6 cabling, make sure you’re using exclusively Cat6 and nothing else.
DO: Limit the length of your cable runs to 300 feet or less to avoid problemsDO NOT: Mix Category 5 and Category 6 cables on the same network DO: Bend the cable gradually when needed and never exceed a 1” bend radiusDO NOT: Untwist more than ½” of each wire pair when building your own cables DO: Keep your cables away from any potential sources of EMI/RFIDO NOT: Use heavy pressure when using zip ties for cable management DO: Always use Category 6 rated jacks with Category 6 cablingDO NOT: Ever under any circumstance splice or bridge a Cat5e or Cat6 cable DO: Always accommodate at least 5 feet of slack in each cable whenever possibleDO NOT: Use standard stapes to secure Cat5 or Cat6 cabling as damage can result DO: If you build your own cables, always verify them with a testerDO NOT: Ever tug or pull excessively on a networking cable
The Time Domain Reflectometry (TDR) test is used not only to determine length, but also to identify the distance to link faults such as shorts and opens. Other techniques for cable length measurement, such as capacitance and DC resistance, are unable to report the distance to a short or open.When a cable tester makes a TDR measurement, it sends a pulse signal into a wire pair and measures the amount of time required for the pulse to return on the same wire pair. When the pulse encounters a variation in impedance, such as an open, short, or poor connection, some portion of the pulse energy is reflected back to the tester. The tester measures the elapsed time between when the pulse was sent and when the reflection was received. In addition to the comparatively large echo or reflection from the end of the cable (open circuit), smaller echoes may be detected that represent impedance changes in the link due to other forms of poor connections or defects in the cable.The size of the reflected pulse is proportional to the change in impedance. Thus, a large change in impedance, such as a short, causes a large reflection; a small impedance change, such as a poor connection, creates a smaller reflection.If a returning echo is larger than a threshold setting (the default is typically about 15 percent of the transmitted pulse), it displays the calculated distance to the echo source. These small echoes are called anomalies and are caused by cable faults of varying severity. Most testers display more than one distance: the distance to the end of the link as well as one or two anomalies along the way. Some of the faults that cause an echo reflection include poor connections, mixed-impedance cable segments, cable stubs, crushed cable, and severe kinks or over-tight tie-wraps. Cable test tools with high sensitivity are able to show a TDR plot that allows the user to see all anomalies along the length of the link.
Fail, *fail, or *pass Possible Cause of Result• Patch cord impedence not 100 ohms• Patch cord mishandling causes changes in impedence• Installation practices (untwists or kinks of cable – the originaltwists should be maintained as much as possible for each wire pair) • Excessive amount of cable jammed into the Telecom Outlet box• Bad connector• Cable impedance not uniform• Cable not 100 ohm• Impedance mismatch at junction between patch cable andhorizontal cable• Poorly matched plug and jack• Use of 120 ohm cable • Service loops in telecommunications closet• Inappropriate autotest selected• Defective link adapter
Note I said name brand manufacture, like Belden.Who buys Chinese CAT6 cable?
