Future Bryston CD Player Still A Go?
0 Members and 1 Guest are viewing this topic. Read 238170 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Future Bryston CD Player Still A Go?
« Reply #500 on: 15 Mar 2020, 06:02 pm »
Hi james
With over 5,000 classical CDs at my disposal, I rely on my BCD-3CD player.
Streaming may be convenient but it falls far short of providing the vast array of music that was recorded on CDs.
Sincerely,
Rima
gberger
  • Check 6
« Reply #501 on: 15 Mar 2020, 07:42 pm »
Hi James,
Another serious vote for the BCD-3.
I've either tried, or owned, CD players since the beginning of the CD era - - - looking for a better one to spin
my expanding collection of classical CDs.  When I found the BCD-3, my hunt was over.
IMO, the "Mini BDA-3" and single clock in the BCD-3 have made all the difference.  My Redbook collection has never sounded better.
BCD-3 > BP17c > 4B cubed > Thiel 2.7s plus sub.   (Sennheiser 800S cans.)
George
linko
« Reply #502 on: 27 Apr 2020, 11:40 pm »
Hi, I just received my BCD 3. I have been playing some CDs today, but really not happy with the sound. I am finding it congested and kind of unfocused. I am doing  an A/B comparison with my audio research CD 2.
How long of a break in is required before the sound becomes as wonderful as everyone is saying. I have it running on repeat. I am going to turn off my other gear tonight (all tubes) and just let the Bryston run.
Any advice?
Mag
« Reply #503 on: 28 Apr 2020, 12:46 am »
Any advice?
Could you provide a little more info like your pre-amp and how you have it connected and digital or analog input/output?
CanadianMaestro
« Reply #504 on: 28 Apr 2020, 01:29 am »
Any advice?
Hi there,
I think you should just give yourself some time to get aurally "adjusted", or acclimated, to the sound of your new player.
I can't imagine why a Bryston CDP would need more "break-in". It already has 100 hrs of run time at the factory before shipping out.
good luck.
p.s. Curious: what was it about the SQ of your ARC CD2 that made you want to buy a BCD-3?
linko
« Reply #505 on: 28 Apr 2020, 10:13 am »
I have the Bryston connected by audio quest coax to my Audio Research LS15 tube preamp, the LS15 feeds a pair of VTL225 tube monoblocks connected to a pair of ProAc responses 3 speakers. I am comparing the BCD3 to my Audio Research CD2 CD player.
Weak signal level as the CD2 is 12 o clock on volume and the BCD3 is 3 o clock.
Much less drive and clarity from the BCD3 veiled sound
linko
« Reply #506 on: 28 Apr 2020, 10:16 am »
I am concerned the ARC CD2 transport will have no repair option as the CD2 has a teacher transport ARC cannot repair or replace. Figured I would get the CD player to last me the next decade.
CanadianMaestro
« Reply #507 on: 28 Apr 2020, 12:39 pm »
Check that the gains on the two separate channels of your LS15 pre (one receiving BCD3, the other CD2) are the same (I have LS27, and the gains can be set independently on each input).
Odd that BCD3 would need a higher volume dial setting. It has a high V out. You said you are using a coax to connect to LS15 -- is that balanced or SE?
Did you check that SPL is the same for both players when comparing?
linko
« Reply #508 on: 28 Apr 2020, 03:14 pm »
Appreciate the detailed response. I can't live with the sound so I am not looking further at the levels but very good idea. I am using SE input. I also connected with a pair of Transparent Audio Ultra XLR to the direct input. Sound just doesn't have musical depth, soundstage is flat. Did quite a few a/b comparisons with the ARC.
SPL ? Sound pressure level?
Mag
« Reply #509 on: 28 Apr 2020, 05:03 pm »
Well I don't know. With my BCD-3 I have to be careful with the volume as I can easily hit high SPL, and I would not describe the sound as veiled. I find the BCD-3 the most refined sound compared to my other sources, BDP-1, Yamaha BD-a1060 and computer output.
I'm using BCD-3 analog outputs to SP2 inputs, using 2 channel bypass to Yamaha MG-10 mixer to Bryston 3B SST2 amps, Model T passive speakers.
Have you tried a firmware update?
CanadianMaestro
« Reply #510 on: 28 Apr 2020, 05:03 pm »
Yes. You said you were A/B 'ing the two CDPs. So you need to make sure that SPL is exactly the same out of your speakers, for both players.
offline for the next day or so.
cheers
loujetlag
Re: Future Bryston CD Player Still A Go?--BOT-1 Discontinued
« Reply #511 on: 30 May 2020, 03:04 pm »
Hi foks, noob on this (and all)  forum here, so please pardon ignorance/etiquette gaffes.
I just acquired a used/IAD upgraded BDP-2.  My plan was to acquire a BOT-1 (used or new) and then pay the factory to upgrade the BDP-2 to a BDP-3.  But now (I believe very recently this month) I see the BOT-1 is discontinued.  And I see it is now out of stock in Sliver (preferred to match my BDP-2) at Moon Audio and in mostly Black elsewhere.
Wondering if I should rush to find a new Silver one out there, wait for a sale, or...?  But meantime some questions...
Does anyone know if there are plans to make a BOT-2?  Or perhaps Bryston is simplifying production and focusing only on BCD-3 and successors?
Also, has any anyone compared SQ of BDP-X + BOT-1 combo vs. BCD-3?
Thanks to all for the fun and knowledge base / resource!
Lou
gbaby
« Reply #512 on: 6 Jun 2020, 04:40 pm »
Lou
Why do you even need a BOT1?
noble
« Reply #513 on: 16 Jul 2020, 02:24 pm »
   Hi there
  Can someone please explain to me as  to  the difference in sound quality between the BCd1 and Bcd3. Is the improvement night and day or should i stick with the bcd1 until it becomes faulty.
 Is there a possibility of a new  bryston CD player in the future.
 Excuse me for my naivety
R. Daneel
« Reply #514 on: 21 Aug 2020, 11:00 am »
Any advice?
Hello!
It hardly makes any sense to me to go from AR to Bryston, unless you're wanting to try "something completely different" as they say in Monty Python.
It is quite possible the Bryston "sound" (if it has any) is not to your liking in general and that you simply bought the wrong machine. If you like your AR player, keep it or try something more recent from AR. Break-in rarely sorted anything out for me. If I don't like it on first listen, I will certainly not like it after a year.
Antun
mav52
« Reply #515 on: 21 Aug 2020, 12:11 pm »
I picked up a BCD-1 years ago, the sound wasn't to my liking , so I just bypassed the internal dac and just use the BCD-1 as a transport fed either by its AES or SPDIF into one of my dacs.
gberger
  • Check 6
« Reply #516 on: 22 Aug 2020, 12:31 am »
The BCD-3 has an excellent transport, and its output goes through the integral BDA-3 DAC components for conversion to analog.  Both the transport and BDA-3 are controlled by a single master  clock, avoiding jitter as much as can be achieved by a CD  spinner i n this price range.
My classical Redbook CD collection is reproduced the best I've encountered so far.
George
AndrewA
« Reply #517 on: 9 Oct 2020, 06:20 pm »
A question.
I remember that the BCD-1 had some special codes that you could type in the remote to reduce the output level a little, to stop it from overloading the preamp, etc.
Does the BCD-3 also have this possible adjustment?  If so, what would the codes be?
« Reply #518 on: 5 Nov 2020, 01:13 pm »
SUBJECT: Bryston BCD-3 CD Player – Customer Feedback
November 2020
Hi James,
I send great opinion from happy customer. He knows what he say about piano because he has been studying piano at University of Music.
Robert Fijałkowski , MJ AUDIO LAB - Poland
"This player is a dream come true for me! I want to hug you and the whole team of Bryston engineers - for the fact that this player was produced and that it sounds the way it does and that I can purchase it.
This device communicates the MUSIC and the emotions associated with it.
I could not ask for anything more. I had high expectations and they came true. A big thank you from me!
From this dat forward, we are changing the Bryston slogan: Bryston is no longer an amplifier specialist; Bryston is a sophisticated music specialist! - This is what Bryston devices sound like, including the BCD-3, which is not an amplifier!  I can attest to the performance because I have already checked it with my own ears. And I know I am right: the BCD-3 player is certainly one of the best players in the world, in an absolute sense.
To say that, I don't need any comparison with other players. I just hear very well; and I know how the different instruments actually sound: and Bryston transmits it. I started with Chopin's Nocturne in C minor (Op. 48) in the recording of my beloved Garrick Ohlsson (Arabesque); and the first two minutes of this recording made me realise what a fantastic player this is.
If the piano sounds like Ohlsson's fingers, the first thing that comes to mind is "yes, no doubt, he's playing the Bosendorfer!" - it cannot be a greater compliment if the device is so accurate in terms of timbre that it differentiates the brand of the piano the artist playing. It calmed me down immediately, because I was sure that since the BCD-3 reproduces the piano sound so phenomenally, other instruments will also sound as they should ... In addition, this sound is already great even when the player is still completely " raw "unplayed ...!" - unbelievable!
To sum up: I bet everything on this player and company. Bryston did not disappoint me. More: they generously endowed me! - And I am grateful to them for that."
ashtarul
« Reply #519 on: 15 Dec 2021, 06:17 am »
Hi James,
Would it be possible to order the BCD-3 with the black and white display like the one on the BR-20?
Ash
