STA-9
Eisener Bart
Re: STA-9
« Reply #140 on: 25 Jun 2016, 06:38 pm »
What are those little stringy wires coming out of the back?
It's wire leading to harmonizer. You may see on photo (right side of Rack).
Armaegis
Re: STA-9
« Reply #141 on: 25 Jun 2016, 07:45 pm »
That... inverted pyramid thing?
audioguy213
Re: STA-9
« Reply #142 on: 25 Jun 2016, 07:56 pm »
reduces EMI/RFI from Alien transmissions
(this is meant in good fun, my own pyramid hat runs on beeswax fuses and a 60V battery)
srb
Re: STA-9
« Reply #143 on: 25 Jun 2016, 08:10 pm »
I avoid hanging antennas off of my equipment unless it's attached to a tuner to specifically to pull in radio or television transmissions.  If I need harmonization I provide that with my vocal chords (to the best of my ability).
bummrush
Re: STA-9
« Reply #144 on: 25 Jun 2016, 08:10 pm »
 What a nice clean setup
Eisener Bart
Re: STA-9
« Reply #145 on: 25 Jun 2016, 08:30 pm »
It works. I don't care how much crazy it looks.
If add this thing ( https://www.acoustic-revive.com/english/roomtuning/rr-77.html ) - will be much better.
Eisener Bart
Re: STA-9
« Reply #146 on: 25 Jun 2016, 08:30 pm »
Thank you.
Eisener Bart
Re: STA-9
« Reply #147 on: 25 Jun 2016, 10:35 pm »
For the moment sound of 2 STA-9 in bridged mode I like less than sound of 1 STA-9 in stereo mode.
2 reasons:
1. STA-9 in stereo mode was feeded by top Power Cable of NeoTech brand.
For 2 bridged amps I have to use 2 Power Cable (self-made) which are absolutely identical.
2. 1 amp I received only yesterday, condition - "from box".
Of course I can hear difference anyhow. 2 monoblocks have crazy dynamic, more control, I can listen music
on very low volume's level, LF is deeper.
Eisener Bart
Re: STA-9
« Reply #148 on: 26 Jun 2016, 11:06 am »
2 pcs STA-9 in bridged mode with my self-made Power Cables sound more ... tuby in LF band.
Eisener Bart
Re: STA-9
« Reply #149 on: 26 Jun 2016, 01:24 pm »
1 more strange thing - I switched on air condition today. No whistling in right channel.
audioguy213
Re: STA-9
« Reply #150 on: 26 Jun 2016, 03:56 pm »
What are your speakers?
4 or 8 ohm?
thanks
Are you using Audio Physic Avanti 89db @4ohm?
I heard that the bridged ST-9 was not so happy with 4 ohm loads, any words on that?
Eisener Bart
Re: STA-9
« Reply #151 on: 26 Jun 2016, 04:03 pm »
4 or 8 ohm?
thanks
Audio Physic
Avanti (first model, 1990)
86 dB
4 Ohm.
Eisener Bart
Re: STA-9
« Reply #152 on: 26 Jun 2016, 04:04 pm »
It's not true.  :D
rustydoglim
Re: STA-9
« Reply #153 on: 26 Jun 2016, 05:56 pm »
Amazing where these "I heard that ..." came from.
By the way, it is STA-9, not ST-9.
Eisener Bart
Re: STA-9
« Reply #154 on: 26 Jun 2016, 05:59 pm »
I guess if I will install 4 STA-9, I can hear everything on whisper volume level.  :green:
John Casler
Re: STA-9
« Reply #155 on: 26 Jun 2016, 06:02 pm »
Or for an additional $400 you can go with the K-38 for 400wpc x 4  :thumb:
Eisener Bart
Re: STA-9
« Reply #156 on: 26 Jun 2016, 06:06 pm »
I am already tied to explain - I can not keep ANY amp between my speakers. My Rack stays on left side, NOT between speakers. I need only mono blocks.
dwaleke
Re: STA-9
« Reply #157 on: 26 Jun 2016, 06:09 pm »
Then put a single amp in your rack on the left side and nothing between your speakers.  Does the K38 not fit in your rack?
Eric Gustafsson
Re: STA-9
« Reply #158 on: 26 Jun 2016, 06:28 pm »
That will be my next step, 4 STA-9. The sound of 2 STA-9 running in bridged mood sounds fantastic. Looking forward to have 4 STA-9.  :drool:
Eisener Bart
Re: STA-9
« Reply #159 on: 26 Jun 2016, 06:32 pm »
Red Cross near the Window - place where I kept Power Amp T+A. First problem - restriction with access to window.
Second problem - all these wires around Power Amp looks not good. Third problem - my youngest daughter used to jump
over the speakers' wires.
My idea - to hide even XLR cable to right channel under the baseboard.
Light green zone near the Window doesn't accept ANY large object. Soundstage ceases from degradation.
