DAC-9
0 Members and 2 Guests are viewing this topic. Read 147763 times.
simon740
Re: DAC-9
« Reply #320 on: 16 Aug 2019, 02:55 pm »
That will work fine, with no issues.
Thank you
regards,
Simon
Jargier
  • Hi
Re: DAC-9
« Reply #321 on: 29 May 2020, 01:23 pm »
Hi everyone.
I have a question. Is it possible to dim the LEDs in Dac-9? Can you insert any foil from the inside? How does it look like?
rustydoglim
Re: DAC-9
« Reply #322 on: 30 May 2020, 12:41 am »
A faster and convenient way is to use a dark marker pen with fine tip to darken the LED without opening up the case.
Jargier
  • Hi
Re: DAC-9
« Reply #323 on: 30 May 2020, 05:14 am »
Dark foil would cover all holes at once. But is it possible to put this film between LED and case? I haven't opened the case yet.
pewe
Re: DAC-9
« Reply #324 on: 7 Nov 2020, 09:19 pm »
I have a DAC-9, very happy with it. But, when using my brand new Onkyo cd-player as a transport to the DAC-9 I sometimes get 1 second long sound drop out. Using the coax input. RCA works perfectly. Is this jitter? How do I fix it ?
rustydoglim
Re: DAC-9
« Reply #325 on: 8 Nov 2020, 04:08 am »
Hard to say if the problem is with the Onkyo CDP or DAC-9. We have sold over a thousand Nuprime CDT-8 Pro and many of them are used with DAC-9, never heard such problem.
pewe
Re: DAC-9
« Reply #326 on: 8 Nov 2020, 09:31 am »
Thank you for your answer. It's a strange problem, never heard of it myself. If someone else here has any experience I appreciate your input.
John Casler
Re: DAC-9
« Reply #327 on: 8 Nov 2020, 05:20 pm »
It could be a "digital handshake" delay.
That means the player, or DAC does not sense and connect to the digital stream immediately.
Not sure of any remedy.  It could be a delay in the DAC sensing the stream, the Player not sending, or a weak cable.
You might try switching cables, as well as COAX and OPTICAL.
pewe
Re: DAC-9
« Reply #328 on: 8 Nov 2020, 06:42 pm »
Thanks John. Must be the cable or the cd-player. I'll try another coaxial cable. It's a shame, because when I use the coaxial input on the DAC-9 the sound is excellent. Just these  distracting drop outs...
Jargier
  • Hi
Re: DAC-9
« Reply #329 on: 9 Nov 2020, 04:39 pm »
I had a similar problem. Two sources / amplifiers were connected and when I only turned on the power one, the signal disappeared from the first one. Weird. Could this be a "ground loop" problem !?
grubyhalo
Re: DAC-9
« Reply #330 on: 15 Dec 2020, 07:03 pm »
Hi all
Does anyone here know the input impedance of the analog line-in for the DAC-9? Thanks in advance.
Cheers.
grubyhalo
Re: DAC-9
« Reply #331 on: 16 Dec 2020, 12:05 pm »
Looks like the Input impedance is 470k Ohms, according to Support
mresseguie
Re: DAC-9
« Reply #332 on: 16 Dec 2020, 02:09 pm »
You found it! Good.
I spent about ten minutes searching the Nuprime website but came up with nothing for the DAC-9.
Michael
robt
Re: DAC-9
« Reply #333 on: 6 Jan 2021, 04:17 pm »
Hi everyone , my first post ! My out of warranty dac 9 got smoked due to a power surge , funny it was the only device in my rack that was damaged ,the transformer had a major meltdown , Nu prime was good enough to send a replacement transformer gratis but it got very hot right away so it was unplugged , so indicates a short on the dac board .Are these boards repairable? Replacement boards from Nu prime are almost $500.00 cdn landed so not worth it .Thanks for your time .
rustydoglim
Re: DAC-9
« Reply #334 on: 10 Jan 2021, 09:33 pm »
You should send the DAC-9 to Aamir to find out what's wrong. Perhaps the power supply is not the only one that got fried.
Was it connected to a quality surge protector ?
yotzee
  • Progressive audiolover
Re: DAC-9
« Reply #335 on: 16 Jan 2021, 11:34 am »
Can someone post witch volume number how much voltage level at XLR or RCA has?
I has a Linn Klout amp on RCA at me. I do not want to owerdrive it!
mchase66
Re: DAC-9
« Reply #336 on: 21 Mar 2021, 06:28 pm »
The earlier threads report that 94 is 2V in, 2V out.
idv_42
Re: DAC-9
« Reply #337 on: 20 Sep 2021, 01:12 pm »
Hi!
Tell me, what is the maximum signal strength on the analog input? 3 volts from Chord Qutest won't overload it?
eljr
Re: DAC-9
« Reply #338 on: 29 Jan 2022, 06:09 pm »
Because of the DAC with headphone amp, so the headphone amp of DAC-10H is more sophisticated than HPA-9 where it has two levels of gain control (H, L and RCA, XLR).  HPA-9 only has H and L gain control.
What is the gain control and when/how do you use it?
rustydoglim
Re: DAC-9
« Reply #339 on: 1 Feb 2022, 05:50 am »
DAC-9 has no gain adjustment.
