DAC-9
0 Members and 1 Guest are viewing this topic. Read 150641 times.
pewe
Re: DAC-9
« Reply #240 on: 12 Aug 2018, 03:00 pm »
Haven't tried a turntable but I'm sure it works fine,  the preamp on the DAC 9 is excellent. I hooked up my old cd player to the RCA input and it almost felt like a new player 😀
simon740
Re: DAC-9
« Reply #241 on: 16 Aug 2018, 01:35 pm »
Thank you @pewe
 One more question: Has anyone connected the phono preamplifier (+ turntable) to the analog input on the DAC-9?
Anybody else?
John Casler
Re: DAC-9
« Reply #242 on: 16 Aug 2018, 06:36 pm »
Thank you @pewe
Anybody else?
I have MANY NuPRIME DAC-9 customers who have done just that, and all are quite happy, and no reported issues.
simon740
Re: DAC-9
« Reply #243 on: 17 Aug 2018, 10:26 am »
What do you think which is better : nuprime dac-9 or Linn Majik Kontrol? Only as a preamp.
I'm looking at Linn because of the phono input. For my Linn Sondek LP12.
regards,
Simon
rustydoglim
Re: DAC-9
« Reply #244 on: 20 Aug 2018, 07:02 am »
In this case you should consider HPA-9
simon740
Re: DAC-9
« Reply #245 on: 20 Aug 2018, 11:01 am »
No no...I will buy a dac-9  :) because I need a DAC too..and because XLR output for my active speakers.
I than I will buy some seperate phono for my LP12.
spidermeng
Re: DAC-9
« Reply #246 on: 25 Aug 2018, 11:11 am »
Hi guys,
I plan to buy official T1A fuse as backup for future.
May i know where can i get it?
Thank you.
mvm
Re: DAC-9
« Reply #247 on: 29 Sep 2018, 12:12 pm »
Can anyone please tell me at what volume level is DAC-9 at 0 gain?
Is the 99th step 0 gain? I've read somewhere its the 94th step or the 81st step. Connection to pre is via RCA, if that makes a difference.
I haven't been able to find a straight answer for this, so some clarity would be greatly appreciated.
Martin
rustydoglim
Re: DAC-9
« Reply #248 on: 1 Oct 2018, 05:41 am »
volume level : 94 = 0dB=4Vrms
mvm
Re: DAC-9
« Reply #249 on: 1 Oct 2018, 10:23 am »
Good morning Rusty,
Thank you for this. Am I then to understand that volume level 47 = 2Vrms?
Best regards,
Martin
rustydoglim
Re: DAC-9
« Reply #250 on: 2 Oct 2018, 04:39 am »
NO, it is not linear.
mvm
Re: DAC-9
« Reply #251 on: 2 Oct 2018, 08:56 am »
Ahh,
So where would 2Vrms be?
Thank you,
Martin
JackD
Re: DAC-9
« Reply #252 on: 3 Oct 2018, 02:37 am »
It's still 94
RafaPolit
    • www.rafaelpolit.com
Re: DAC-9
« Reply #253 on: 3 Oct 2018, 04:37 am »
???? What? No, obviously not! 94 will give 4V Rms max, when the input is 2V Rms.  So no, 94 is NOT 2V Rms, and knowing the 2V Rms max is useful if you are looking to use the DAC to input another PRE (obviously, not bypassing the PRE functionality itself) for those PREs that have a maximum input of 2.3VRms, which is very common.  So please don't confuse people that are asking genuinely useful questions!
JackD
Re: DAC-9
« Reply #254 on: 3 Oct 2018, 05:29 am »
Rafa
You are wrong. The unity gain setting for the DAC-9 is 94 for either output just like it is 93 for both outputs on the DAC-10.  The SE voltage is half of the voltage of the XLR output but it takes the same gain setting to get there. Not sure as an IDA-8 owner how you would know I was wrong.  I actually have experience with the gear in question or I don't answer or get involved.
mvm
Re: DAC-9
« Reply #255 on: 3 Oct 2018, 09:27 am »
Jack how can a volume level of 94 be both 4Vrms, and 2Vrms simultaneously?
RafaPolit
Re: DAC-9
« Reply #256 on: 3 Oct 2018, 01:26 pm »
JackD, the unity gain on the DAC-10 is 93 for the low gain setting where you get 2V in and 2V out.  At the high gain setting, at 93 vol you have 2V in and 4V out.
The fact that with the DAC-9 you don't get switchable gain, it always stays at this 'high' value.  While I agree that 94 is the value where the signal is not affected by the attenuation or volume control, there is still a 6dB (double voltage) gain.  At full 2V in, that would yield 4V out.
There are a number of devices that have a max input of 2V.  So, for those, and having a fixed gain setting, we would need to know the volume value that, while attenuating and possibly degrading ever so lightly the signal, achieve a 2V output.
And it doesn't matter at all what equipment I have to know you could be wrong, but I have DAC-10, ST-10 and uDSD.  Never have seen an Ida-8.  Not sure how that was relevant, though.
Rafa.
JackD
Re: DAC-9
« Reply #257 on: 3 Oct 2018, 03:07 pm »
Rafa
If we use your and mvm's logic and the unity gain setting on the DAC-10 for 2 volts is 93 on the low setting for the SE outputs then tell me what it is for the XLR outputs
on the low gain setting since the volume control only goes to 99. A simple solution to this is to use both outputs and measure with an actual SPL meter or an SPL app on your phone.  The voltage output on the DAC-9's outputs are standard. Voltage and gain are not the same things.
mvm
Re: DAC-9
« Reply #258 on: 3 Oct 2018, 10:51 pm »
Jack, I wasn't arguing with you, I was asking.
To be honest I still don't actually understand how it could be the same at the same attenuation level?
Best,
M,
JackD
Re: DAC-9
« Reply #259 on: 4 Oct 2018, 12:20 am »
mvm
Changing from the SE to the XLR outputs involves changing the output voltage not the gain supplied to the outputs.  From the website product description.
"Individually adjustable volume on each input for precise level matching of sources. If DAC-9 is connected to another preamp or home theater AVP, set the volume @ 94, which is 0dB." No differentiation of outputs is listed.
