0 Members and 1 Guest are viewing this topic. Read 8087 times.
With this DAC using XLR avoids going through an opamp doing the bal/unbalanced conversion in the single-ended path.
while at least one person has said that he had cables made to send the XLR to RCA with a resistor to match the impedance of his amp, and that it made a huge difference in his Yggy, opening up the soundstage and the improving resolution. Does he just "think" he's hearing that huge improvement?
I respect the designer's opinion that the RCA output is well engineered:
If this is the case for the Yggy, then I have no trouble believing that the XLR output sounds better, but using an XLR to RCA adapter is not the best way to do it. Sure, it might sound a bit better than the unbalanced out this way. However, using a very high quality signal transformer, differential mode, to convert the balanced to unbalanced would be ALLOT better, assuming the Yggy has the drive to run the transformer.
You know Mike is really not a big fan of usb but includes it on his products due to market realities.
