BDA-3 DAC
0 Members and 4 Guests are viewing this topic. Read 753978 times.
Slam Dancer
Re: BDA-3 DAC
« Reply #720 on: 28 Feb 2017, 01:38 pm »
Update: only red lights on the HDMI inputs...  :o
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-3 DAC
« Reply #721 on: 28 Feb 2017, 02:32 pm »
Hi
Yes the source is not sending a signal for some reason and the BDA3 is loosing lock.  With sources that do not default to no signal there is no issue.
james
Slam Dancer
Re: BDA-3 DAC
« Reply #722 on: 28 Feb 2017, 02:49 pm »
Seems like the sources are sending signals, I hooked them directly to the TV and then everything is ok.
Re: BDA-3 DAC
« Reply #723 on: 28 Feb 2017, 04:03 pm »
Its strange - lets see what Mike has to say.
james
Slam Dancer
Re: BDA-3 DAC
« Reply #724 on: 7 Mar 2017, 09:57 am »
Back on track again!  :D
Thanks to the guys at Bryston!
Re: BDA-3 DAC
« Reply #725 on: 7 Mar 2017, 10:47 am »
What was the issue?
james
Slam Dancer
Re: BDA-3 DAC
« Reply #726 on: 7 Mar 2017, 11:56 am »
One of the ribbon cables connected to the HDMI board was quite loose.
Hooked it up again - and now all seems to be working perfect again.
How the cable got loose is a little odd, since the BDA-3 has not been moved around after I got it.
But thanks again for your help.
Raimo
Re: BDA-3 DAC
« Reply #727 on: 7 Mar 2017, 04:49 pm »
Hallo James, when could i expect to get my BDA3 that i ordered in late January? According to the sales man it should have left Bryston early in February.
Best regards Raimo.
Re: BDA-3 DAC
« Reply #728 on: 7 Mar 2017, 05:24 pm »
Best regards Raimo.
Hi Raimo
What dealer and I will check.
james
Raimo
Re: BDA-3 DAC
« Reply #729 on: 8 Mar 2017, 07:11 am »
Hi Raimo
james
It is Digital Audio in Lithuania. It was a deal with a ex demo 4B3 and a new BDA3.
Best regards Raimo.
Grant Hill
Re: BDA-3 DAC
« Reply #730 on: 8 Mar 2017, 11:17 am »
Best regards Raimo.
wow! congrats!  :thumb:
Re: BDA-3 DAC
« Reply #731 on: 8 Mar 2017, 03:38 pm »
Best regards Raimo.
Hi Raimo
From Export:
They should have this now...was shipped in Feb.
Raimo
Re: BDA-3 DAC
« Reply #732 on: 8 Mar 2017, 06:16 pm »
Hi Raimo
From Export:
Thank you very much, i will contact them.
Best regards Raimo.
Raimo
Re: BDA-3 DAC
« Reply #733 on: 8 Mar 2017, 06:18 pm »
Thanks :D Love the amp, looking forward to hear the Dac :P
Grant Hill
Re: BDA-3 DAC
« Reply #734 on: 8 Mar 2017, 06:30 pm »
Hi Raimo,
I think you're gonna like it!
Raimo
Re: BDA-3 DAC
« Reply #735 on: 9 Mar 2017, 07:38 pm »
Now it has arrived to the shop and will be shipped to me tomorrow. I am very excited to hear it :P.
I really like the BDA1 specially in combination with the 4B3, with my 4BSST it sounded more harsh.
My old reference player Pioneer DV668 was often a better match with the 4BSST depending on the recording.
I really hope and think that the BDA3 will outperforme both of them.
CanadianMaestro
Re: BDA-3 DAC
« Reply #736 on: 9 Mar 2017, 07:44 pm »
Congrats and do keep BOTH DACs. I find the BDA-1 has that analog-like mojo and superb soundstage that are irresistible for PCM files.
Nothing succeeds like excess.  :thumb:
Haven't heard the BDA-3, don't plan to, either.
The Rang
Re: BDA-3 DAC
« Reply #737 on: 10 Mar 2017, 01:42 am »
It was years between my auditions of the BDA-1 and the BDA-3 (tough to compare based on memory) but I can say your description of the BDA-1 having an analog-like mojo and superb soundstage applies to the BDA-3 as well.
Sadly, after almost $1600 of unexpected repairs to my wife's car, my order of a BDA-3 has been delayed for a few more months
CanadianMaestro
Re: BDA-3 DAC
« Reply #738 on: 10 Mar 2017, 02:37 am »
More the reason for me to stick with my beloved BDA-1 !   :thumb:
Hope you eventually get to do the -3.  WAF or no WAF.....
 :green:
Kusot
BDA-3 Audio Return Channel
« Reply #739 on: 10 Mar 2017, 06:58 am »
Does the BDA-3 have ARC?
Today, watching a blu ray (Oppo) with sound on my stereo, I have HDMI to the tv and optic to my BDA-1. Watching regular or smart TV the sound is also sent optical to my BDA-1 from the TV. I am waiting for my BDA-3 and plan to run the blu ray through the BDA-3 to the TV, expecting this to be an upgrade. Will I still need the optical( or a second hdmi) from my tv to my BDA-3? My tv is ARC ready and I used to have a receiver accepting the return channel.
