BDA-3 DAC
0 Members and 3 Guests are viewing this topic. Read 753951 times.
XMAN
Re: BDA-3 DAC
« Reply #380 on: 25 Mar 2016, 06:56 pm »
I just received my bda just wondering how often and how to update firmware
scottsol
Re: BDA-3 DAC
« Reply #381 on: 25 Mar 2016, 09:02 pm »
I understand that the BR2 cannot select the HDMI inputs, but are there codes that the BDA-3 will respond to?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-3 DAC
« Reply #382 on: 25 Mar 2016, 10:33 pm »
Not sure.  Email Mike on that. [email protected]
guyguay
Re: BDA-3 DAC
« Reply #383 on: 25 Mar 2016, 11:00 pm »
You Have to used HEX CODES (Discrete Codes) with a universal remote Control
Mike Can Send you thoses Codes
I am using HEX CODES for my Bryston Gear
Martin
stereoal
Re: BDA-3 DAC
« Reply #384 on: 29 Mar 2016, 07:01 am »
I've just ordered a BDA-3 to replace my BDA-1, which is moving to my basement system.  I'm wondering if I can plug my laptop into the BDA-3's USB port without turning the BDA-3 off. The manual for the BDA-1 says not to hot swap, but there is no such warning for the BDA 3. I was hoping to just leave the USB cable plugged into the back of the BDA-3 at all times and plug and unplug my laptop in as needed.
CanadianMaestro
Re: BDA-3 DAC
« Reply #385 on: 29 Mar 2016, 12:03 pm »
I always turn off BDA-1 to switch out ICs or pc's. Just to be safe. Takes just a split second to hit the power button on BDA.
Grit
  • - Garrett
Re: BDA-3 DAC
« Reply #386 on: 29 Mar 2016, 03:42 pm »
You might consider switching inputs when you do it, toggling the BDA-3 to an unused input, then toggling it back to the USB input once the laptop is connected.
Re: BDA-3 DAC
« Reply #387 on: 30 Mar 2016, 03:35 pm »
Hi Folks,
First German review on our BDA-3 DAC :thumb:
We have recently online first review on BDA-3:
http://www.hifistatement.net/tests/item/1708-bryston-bda-3
Best regards
Edvard
Grant Hill
Re: BDA-3 DAC
« Reply #388 on: 30 Mar 2016, 05:14 pm »
... what about a review in English? :-)
CanadianMaestro
Re: BDA-3 DAC
« Reply #389 on: 30 Mar 2016, 05:17 pm »
You're an American? Not everyone in the world writes English.
Google Translate might help here.
Re: BDA-3 DAC
« Reply #390 on: 30 Mar 2016, 05:17 pm »
I have a few on the go
james
NekoAudio
    • Neko Audio LLC
Re: BDA-3 DAC
« Reply #391 on: 30 Mar 2016, 08:27 pm »
I have not run into any problems with hot plugging the USB input with the BDA-3, including unplugging/plugging-in at the computer end like you described.
srb
Re: BDA-3 DAC
« Reply #392 on: 30 Mar 2016, 08:45 pm »
By definition, the USB specification allows for hot swapping / plugging.  I've personally never ran into a problem on any computer or device since USB 1.0 was officially released in 1996.
Manufacturers who may post warnings against such, are probably trying to eliminate any possibility of data corruption to hard drives or memory modules that are being actively written to while being unplugged.  Depending on the OS and firmware, this could be sometime after the command was executed due to delayed cache writing.
That's the only reason Windows PCs have a USB device eject function in the system tray / notification area of the taskbar.
mav52
Re: BDA-3 DAC
« Reply #393 on: 30 Mar 2016, 09:01 pm »
Use Chrome it will translate it.
Renato6
Re: BDA-3 DAC
« Reply #394 on: 31 Mar 2016, 02:30 am »
Loving my BDA-3.
I've had it for about a month. A few times I've noticed that it won't turn it on with the power button. I have to unplug the power cable and then press the power button and it turns on.
Any thoughts or has anyone else experienced this?
Yitshak
Re: BDA-3 DAC
« Reply #395 on: 31 Mar 2016, 04:40 am »
Loving my BDA-3.
Happened to me yesterday first time.
no unplug was needed as it turn on after 3 or so more press,
It's working fine for now (just checked).
Grant Hill
Re: BDA-3 DAC
« Reply #396 on: 31 Mar 2016, 08:19 am »
Grant Hill
Re: BDA-3 DAC
« Reply #397 on: 31 Mar 2016, 08:20 am »
I will
Re: BDA-3 DAC
« Reply #398 on: 31 Mar 2016, 12:05 pm »
Hi Folks,
Best regards
Edvard
Hi James
A lengthy and very informative review in German which begins and ends with respect and approval of the company and its products — excellent !
Ernie Fisher
Inner Ear Report
BSMSPEMBA
Re: BDA-3 DAC
« Reply #399 on: 31 Mar 2016, 12:23 pm »
Loving my BDA-3.
This happens to me regularly.  Remote only powers up the BDA-3 about 50% of the time.  The power button is also unreliable.  I have to use multiple presses of the power button to get the unit to fire up.
