BDA-3 DAC
0 Members and 3 Guests are viewing this topic. Read 753899 times.
Grant Hill
Re: BDA-3 DAC
« Reply #240 on: 11 Feb 2016, 02:52 pm »
Great, I will. Thanks a lot!
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-3 DAC
« Reply #241 on: 11 Feb 2016, 05:20 pm »
Ok, thanks. I downloaded the driver easily with my laptop.
Does anyone know how to configure foobar2000 in order to play dsd files natively? I tried but the light on the bda3 was PCM and not DSD...
http://www.audiostream.com/content/how-play-dsd-file-using-foobar2000#EJF6j6uLjabEtSp3.97
Grant Hill
Re: BDA-3 DAC
« Reply #242 on: 11 Feb 2016, 05:25 pm »
Thank you James..
the missing step I think was this one:
http://cdn.audiostream.com/images/9513foobar1.png
I hope I'll able to make it
Grant Hill
Re: BDA-3 DAC
« Reply #243 on: 11 Feb 2016, 07:51 pm »
James,
Does the bda3 need a break-in period?
Re: BDA-3 DAC
« Reply #244 on: 11 Feb 2016, 07:52 pm »
James,
No - the customer does - LOL
james
Grant Hill
Re: BDA-3 DAC
« Reply #245 on: 11 Feb 2016, 08:42 pm »
 :D
james
Re: BDA-3 DAC
« Reply #246 on: 11 Feb 2016, 08:47 pm »
:D
Hi Grant
Seriously  though ... the engineers will never agree but I find after about 3 days things start to sound more coherent and more spacious with better tonal balance.
james
Grant Hill
Re: BDA-3 DAC
« Reply #247 on: 12 Feb 2016, 08:56 am »
Hi,
I don't know if this is the right place to talk about my issue, if not please let me know and I will open a dedicated tread. I still not able to play dsds files.
here a screenshot of Foobar on my system:
Grant Hill
Re: BDA-3 DAC
« Reply #248 on: 12 Feb 2016, 09:01 am »
then I move to Tools and select SACD like this way
on the ASIO Driver Mode dropdown I select "DSD". Then apply and play.
With this configuration I cannot play files at all.
If i select PCM on the ASIO Driver Mode it plays, but the light indicates PCM 88.2 (or 176.4), not DSD.
Does anyone know the reason why?  :cry:
Re: BDA-3 DAC
« Reply #249 on: 12 Feb 2016, 10:54 am »
Grant
What is your source component - a laptop ?
DSD is only available with USB
Also in Manic Moose make sure you go into the AUDIO DEVICES settings at the bottom of the page and select (enable) and checkmark the soundcard.
james
« Last Edit: 12 Feb 2016, 01:38 pm by James Tanner »
Grant Hill
Re: BDA-3 DAC
« Reply #250 on: 12 Feb 2016, 01:25 pm »
Hi James
no, it is desktop. I use foobar2000 with USB to BDA3. Of course I installed Bryston's driver. I do not use Manic Mouse.
Re: BDA-3 DAC
« Reply #251 on: 12 Feb 2016, 01:40 pm »
Hi James
OK I have foobar2000 on my windows computer at work so I will check.  Also maybe try JRiver as well as that works very well in my setup.
james
audio.bill
Re: BDA-3 DAC
« Reply #252 on: 12 Feb 2016, 01:55 pm »
I don't use foobar (JRiver instead) but looking over your settings I suspect that the issue might related to the DSD2PCM Mode. If there's an off or none setting that may be it, since you don't want to convert your DSD to PCM which appears to be what's happening since you're getting PCM instead of DSD.
Grant Hill
Re: BDA-3 DAC
« Reply #253 on: 12 Feb 2016, 02:07 pm »
Thank you!
Grant Hill
Re: BDA-3 DAC
« Reply #254 on: 12 Feb 2016, 02:08 pm »
Sorry, I forgot to tell you that I selected "none". I agree with you.
audio.bill
Re: BDA-3 DAC
« Reply #255 on: 12 Feb 2016, 04:09 pm »
That's probably the first time someone agreed with me on an audio forum!  :) So do I understand that even with DSD2PCM Mode set to 'none' you're still receiving PCM at the DAC? If so I'm afraid I can't be of more help. Seems like an experienced foobar user should be able to help.
Re: BDA-3 DAC
« Reply #256 on: 12 Feb 2016, 04:14 pm »
Here are my settings if this helps:
james
Grant Hill
Re: BDA-3 DAC
« Reply #257 on: 12 Feb 2016, 04:28 pm »
Thank you very much James.
I will try asap.
Grant Hill
Re: BDA-3 DAC
« Reply #258 on: 12 Feb 2016, 06:47 pm »
I got different screens... on the first one, the Device is ASIO: Bryston USB ASIO Driver, while yours is DSD ASIO: Bryston USB ASIO Driver..
maybe this is the problem.
Grant Hill
Re: BDA-3 DAC
« Reply #259 on: 12 Feb 2016, 08:23 pm »
Ok, I uninstalled foobar2000 and then I downoloaded again. I installed with only few components like foo_out_asio.fb2k-component and foo_input_sacd-0.6.0.zip.
Now it works  :thumb:
thank you everybody for your help and support!
ps: in Output node in the Device dropdown I had to select foo_dsd_asio... with Bryston USB Audio ASIO Driver it wasn't working...
