You are 100% correct. All codecs are decoded and converted to PCM within the player. The buffer in the media player that contains the PCM data has no idea what went on before. It just gets the PCM data, which is identical from all lossless codecs, and outputs to the DAC. Dynamic playback makes no difference.This is easily verified by internally routing the input of a multi-channel DAC back to an output and passing on to program for recording.To go along with Tommy's analogy, it is like me receiving 3 identical Word documents compressed with .zip, .rar, and .7z. I decompress and save all three documents. I later view the three documents. I no longer know which compression method was used and all documents are identical.People do this all the time with video files and nobody ever notices a difference - and with video you have both sight and sound to help discern things. You can rip a DVD and keep the original ISO, extract to TS folders, or convert to MKV. ISO and MKV are just containers like zip, flac, or any other lossless container.
If you believe this, then why does every player software sound different? Why do different lossless compression formats sound different (FLAC, uncompressed FLAC, ALAC, AIFF)?Steve N.
Throwing me a softball?
To quote Mitcho in his FLAC vs WAV article, "if you are hearing an audible difference, then the waveform must have changed. If the waveform has changed then we can measure the difference."
I currently have DACs with the following digital output or input:FirewireAsynchronous USBAdaptive USBS/PDIF OpticalS/PDIF CoaxADAT LightpipeAES3ThunderboltEthernet (AVB)About the only thing I don't have currently is MADI and I2S although I2S is often used internally.I think I can make a signal chain that looks like this:Media Player > Firewire > DAC > S/SPIF > DAC > Media Player > USB > DAC > Ethernet > DAC > Media PlayerThe signal passes through 4 DACs and the Media player handles it 3 times. All interfaces have an opportunity to affect the signal and jitter can be accumulated. Furthermore, the cables, the PC itself, and the media player can change the data. Will the final recorded file be identical to the original? In other words, has anything in the signal chain been able to affect the data at all? As a bonus I can run a stress test program(s) on the PC to max out the CPU and GPU.If I post 19 original files and 1 file that has been through the long, arduous, precarious, fraught with peril, digital pathway, will anyone even be able to pick out which file isn't the original?Most, myself included , think that the squares marked A and B are different shades of grey, but that doesn't make them right. The two squares are identical. Perceiving something as different doesn't make it different.
Back to minimalist high performance. One reason for minimalism is NOT related to cost. We are attempting to cut the analog path down to almost nothing. Balanced connection to the amp with known characteristics is much more forgiving than single ended.
If someone else out there has a SB Touch type device with coax SPDIF out, I'd like to know.
Tommy, check out the Bluesound Node 2 as a new Touch-like device w spdif out.
Just to touch on the output end of the Minamilist system for a moment....I had the opportunity to sample a pair of Klipsch bookshelf speakers today. Now, this pair aren't quite broken in yet to my ears, but I've heard them 1/2 dozen times on other vintage receivers. Just last night they were driven by an all tubed SonicFrontiers integrated, and a very nice vintage Pioneer receiver that was much better than I expected. However, compared to my Maraschino's playing a $10k pair of speakers, I thought the Klipsh/integrated combo sounded grey, thin, and uninvolving. The treble was always too forward and harsh. We tried one more pairing..... DAC DAC -> MARASCHINO'S -> Klipsch. Holy Shift! Suddenly the previously forward treble sounded more refined, and the speaker made better bass. The lower registers of familiar music stopped and started quicker. The midrange began to show promise. And imaging, oh my god! These little $500 bookshelf speakers sold at BestBuy never sounded like this before. I think a few more hours of good loud tunes to loosen up the firmly hung woofers and these little guys will be a great little system. It was as if the amps were able to see past the crossover and just made the drivers work better. Point here is, a good simple system was sitting here waiting to be found, and it came to life with the Maraschino's doing the heavy lifting. Plenty of gain and ample volume in a 13x16x9h room. Think of all the bargain speakers waiting to be woken up by the Maraschino amps. This is going to be FUN!
Tommy, They were RB61. I edited above. Discontinued now, but these have good sound, bi-wire capable, and solid build on top of that great sound. Might be good candidate for hanging Maraschino too once I come up with stands.
Thanks again. Check out this bi-wire In-Line Maraschino hook-up:
Seems pretty cool, but no touch screen. Sometimes, I use the touch for a background music source, playing tunes loudly in another room while I cook (food), for example. It's good to have the touchscreen so my kids can change the volume or track themselves. I control the music from my iPhone with the free Logitech application.Otherwise, looks like a great source device, and costs less than most PC based solutions. Plus, it's a good size, easy to place near the DAC DAC so you can use a short SPDIF cable.Thanks for your post.
