What are your power supplies?
JRiver has a 64-bit volume control????http://wiki.jriver.com/index.php/VolumeSeems overkill, but maybe they just do everything with 64-bit resolution anyway.Can anyone verify this?
I'm going to throw in my experience with digital volume controls. The best one I have found is with Amarra. Very transparent, provided that you only attenuate less than 10dB. With more than 10dB attenuation I have heard distortion with all digital volumes, at least with my highly resolving system. In most systems 10dB is insufficient, therefore when I have used it I also used another analog attenuator or similar at the same time.At shows for instance, mostly for convenience, I used a digital volume control only after reducing the volume with my DAC volume, which is exactly like directly connecting the line outs to the amps. This way I can provide a good level for all tracks without exceeding -10dB on the digital volume. My DAC volume control is unique in the industry because it uses no attenuator, gain control or decimation.Steve N.Empirical Audio
The internal DSP path of JRiver is 64-bit floating point on their Windows, MAC, and Linux versions. This ensures that all DSP is done with maximum precision. However, the bit-depth of your DAC chips determines the final output. JRiver has two dither methods available for the highest quality output and volume control. The default method is what they call JRiver Bit-Exact and ensures that any conversion to 64-bit and back to the DAC bitdepth, without any DSP, is completely bit-perfect. You can also use Triangular Probability Density Function (TPDF) dithering. If you compare both with an oscilloscope, you will see that TPDF has lower noise overall and pushes the noise above the audible bandwidth.Most DAC's with an ASIO driver will request the data as 32-bits even though the final output may be 24-bit. This is because ASIO requires a 32-bit pipeline to be open to the audio device. To deal with this, JRiver allows one to specify the bit-depth of the final DAC chip. If the final output is 24-bit, JRiver will dither to 24-bits and pad the output to 32-bits to comply with the ASIO requirement. Other software will dither to 32-bit and the DAC will truncate to 24-bit and you get reports of digital volume control not sounding that great. So, with JRiver all volume control is done at 64-bits and dithered to either 24 or 32-bits for output. This means that you can use volume control with a 24-bit DAC and use up to -60 dB of attenuation without any audible artifacts. With a 32-bit DAC you get more attenuation than is ever necessary.With Maraschino Cherry amps and high efficiency JTR Speakers, it was demonstrated at RMAF last year (24-bit) and this year (32-bit) that digital volume control is implemented in such a way in JRiver that it is completely lossless even for 24-bit. When you playback in a range of over 100 dB at the show (maximum around 132 dB), it gives the listeners the opportunity to notice any audible artifacts.
Steve,I guess results vary a lot system-to-system. I've had "way beyond very good" results with digital volume control on both the systems described at the beginning of this thread, and other setups, even when attenuated heavily in a very quiet room, medium efficiency speakers. With DAC DAC, listeners are also experiencing excellent results with digital volume control on a variety of speakers/amps.The upcoming MINT amplifier has a volume control, and I've actually experienced better results with the TL version of DAC DAC driving the MINT with the volume digitally attenuated and the MINT's volume at full blast. When the opposite is true, distortion is measurably higher, and you can definitely hear the difference. Another point (don't remember seeing it on this thread before) is that the gain of the rest of the system must be set correctly for this to work. I'm typically driving Maraschino Cherry monoblocks, and they have relatively low gain (22dB), and the DAC DAC is designed to provide full scale output of 4.5Vrms. When you do the math, this allows the DAC to drive the amps a few dB into clipping, even with the 60V power supply. The MINT has slightly higher gain (24dB) with the volume all the way up, so the DAC can send it farther into clipping. Either way, the background is super quiet because the DAC DAC's SNR is better than 120dB (both versions). Add a preamp, and you know....Are you familiar with the ESS volume control in their D/A chips? What do you think of their chips versus TI/BB and others?Thanks for your post.-Tommy O
Try this at home. Using a dead simple iTunes interface. Turn the volume down as far as iTunes allows and with your own dac directly connected to your amps, do you still have good clean wiry bass? Does your system still layer and image in front and behind and beyond the outer edges of the speaker baffles. Do you still find the music involving, the lyrics engaging. Can you tell the emotional intent of the performance. This is what I hear, when iTunes is completely throttled down.
Steve - we are all at different levels in our personal audio evolution. One mans excellent is anothers mediocre. I have no doubts that the amps are excellent. Its the source that I have doubts about.I have listened to iTunes plenty of times. I hear detail and good bass, but the detail is not focused or 3-D as when using my particular version of Amarra (not the latest BTW). The better the rendering, the better the engagement and listening involvement. If I had used iTunes at shows, I guarantee I would never have gotten best of shows, which I have several. My DAC only connects directly to my amps. The volume control has no parts in the signal path.BTW, I have a TVC. Its an $8K pure silver Music First and although its very good, it still has an audible effect on the music, so I don't use it.Steve N.
If "whatever" media player software is playing lossless tracks, and the gain is set to unity (no attenuation), how could the data (not the timing, just the DATA) fed to the DAC be any different?
How can you control the volume without touching the signal (you said "no parts in the signal path")?
Thanks SteveN I have read several individuals seem to think the fully silver versions of TVC by any manufacturer to have a slightly drying effect on the sound. That's why I stuck with copper wiring for my choice. Perhaps silver having a much faster signal propagation somehow suffers at the induction part of the path as concerns the windings in the transformers?
My point being that if you hang DACDAC behind an inferior passive or active Analog volume control you WILL kill the magic and miss the point of this devices' inherent strengths.
It sounds drier because of all of the fractures in the silver crystal lattice. Silver done right does not have this effect. Silver wire can suffer from the same thing. That is why I had the Music First TVC cryo-treated by a competent company. It fixes most of that. Silver wire if annealed properly will not have this problem either. I used to sell silver IC's and I actually have that cable company up for sale.
The CODECs are different and sometimes the offset is incorrect, particularly with iTunes on a PC. There is the data, the control info and the offset as well as the jitter. I have this discussion a lot with folks that have not tried a lot of different players on a highly resolving system. I have examples of tracks with different offsets and the same music data and they all sound different, does not matter what player you use.
I control the volume in my Overdrive DAC by changing the D/A reference voltage. This is the voltage "height" of the stairsteps.
A lossless codec, if working properly, will output the same data as any other properly working lossless codec, and the offset should also be the same. It's like a ZIP file. Carbon copy of the data, offset and all.
That works, but you lose more dynamic range doing that than you gain by having "analog volume" (:
In theory, yes. In practice, no. Dynamic playback has its issues.
