0 Members and 1 Guest are viewing this topic. Read 5532 times.
I encourage you to try High Pass Filtering on your Monitors. Personally, I've used a number of High Pass Filter methods over the years and to my ears the Crossover did more harm than good. Wonder why Omega's don't have a crossover? My system is very simple, Oppo Player, one pair of interconnects, Decware Amp, Speaker Cables, Omegas. If you throw a pre-amp and other devices into the audio chain then any negative effects of the crossover my be less noticeable.
PeterI've not used the Marchand xover but understand they are top of the line. Which model are you using?
Thanks! Is Marchand better than miniDSP? miniDSP seem to provide a whole lot more functions including EQ and room correction. They have a bewildering array of options. Thanks,UL
