Wall Mount?
0 Members and 1 Guest are viewing this topic. Read 2423 times.
Folsom
Wall Mount?
« on: 29 Oct 2015, 09:59 pm »
Hi guys,
I need a wall mount, articulating, that extends beyond 23". Basically I have a hole for a CRT TV at 23-23.5 inches. Right now the TV (vizio sony) is on a stand and sitting right outside of this. But I'd like to make it more secure and gain a little better tilt on it.
I was looking at Wall Mount World, but I haven't a clue if they're reputable. The problem with looking on other websites is they don't tell you or won't let you search for depth.
Any suggestions would be appreciated.
ctviggen
Re: Wall Mount?
« Reply #1 on: 29 Oct 2015, 11:25 pm »
Monoprice has some of these.  I never used them, though.
http://www.monoprice.com/category/tv-wall-mounts/full-motion-tv-wall-mounts
If you go to shop categories, they also have tilt models.
GentleBender
Re: Wall Mount?
« Reply #2 on: 30 Oct 2015, 08:21 am »
A hole for a CRT TV? Could you provide a picture of the location? Trying to understand the issue.
youravhandyman
Re: Wall Mount?
« Reply #3 on: 30 Oct 2015, 12:32 pm »
I'm a custom integrator so I have used several and this one http://www.skywalker.com/Products/Royal-Mounts-Universal-Articulating-Mount-with-Dual-Arms-for-Large-42-90in-displays__ROY6607B.aspx is my "go to" motion mount.  If you have a local integrator that you work through to get you this mount I do suggest this product.  It is solid and heavy so having the display extended beyond 23 inches is no sweat for it.  Max extension is 30 inches and it supports 42 to 90 inch displays.  If you run out of options then PM me and I can help you out.
Matt
mcgsxr
Re: Wall Mount?
« Reply #4 on: 30 Oct 2015, 04:43 pm »
Might be simpler and cheaper to frame in some supports and use a traditional mount.
The tv when mounted would cover the DIY solution "in the hole".
Folsom
Re: Wall Mount?
« Reply #5 on: 30 Oct 2015, 06:24 pm »
Yes and no.
I'd have to move the electrical forward if I made another wall in it. And the receiver sits inside the hole, so I'm more interested in the mount.
I'm not sure I know any installers (in town), but I'll think on it. (I did just move)
Phil A
Re: Wall Mount?
« Reply #6 on: 30 Oct 2015, 06:36 pm »
Yes and no.
CEDIA can give you a list - http://www.cedia.org/find-a-cedia-professional
Folsom
Re: Wall Mount?
« Reply #7 on: 30 Oct 2015, 06:43 pm »
All I get is Huppins, that is a store for stuff. Maybe these guys.
Phil A
Re: Wall Mount?
« Reply #8 on: 30 Oct 2015, 07:23 pm »
I'm sure there are many and other sources (besides CEDIA) to find someone.  If you increase the distance to 50 miles, I get two from CEDIA:
2 RESULTS
Please note: CEDIA member companies with CEDIA certified employees will be displayed first.
Huppin's / OneCall
Proximity: 8.9 miles
P.O. Box 13069
Spokane, WA 99213 | USA
Read More
Center on Map
Audio/Video Solutions, Inc
Proximity: 32.1 miles
916 Lincoln Way
Coeur d'Alene, ID 83814 | USA
Read More
Phil A
Re: Wall Mount?
« Reply #9 on: 30 Oct 2015, 07:26 pm »
I've been to the One Call website before if that is affiliated with Huppins - http://onecall.com/
If you go to Yelp you can find more as well:
http://www.yelp.com/search?find_desc=home+audio+installation&find_loc=spokane+washington&ns=1
mcgsxr
Re: Wall Mount?
« Reply #10 on: 30 Oct 2015, 07:37 pm »
Understood about the complications if you built in a whole wall.
I was just envisioning a 2x6 attached in a place that you could "mount a mount" on - boy that sounds odd to say out loud!
Perhaps the other "pro" solutions are in fact worth the $ and effort for your specific application.
Good luck, sounds like a cool project.
Phil A
Re: Wall Mount?
« Reply #11 on: 31 Oct 2015, 12:51 am »
In my old place I had a 55 inch backlit LED held up by an articulating bracket I got at Costco (they usually have a few in the store and then more online - http://www.costco.com/tv-mounts.html).  The TV was heavy so I needed help.  Actually once we got it up we needed another person to just push it into place.  I also had another TV mounted above a fireplace in the kitchen.  I don't know if I would do another wall mount (especially given how thin current TVs are) vs. attaching a secure shelf at the proper height.  Pics of my old house below.
