0 Members and 3 Guests are viewing this topic. Read 409695 times.
Thanks Folsom ! I will drill in the top also
Anyone have a recommendation for IEC connector with fuse builtin. Need something to use with antipole.
Thanks for the link on how to drill evenly spaced holes. I'll probably add those to the top . To start I drilled 5/32nd holes between each heat sink fin on the bottom and top of the chassis and also a row on the top of the chassis back. Putting rubber washers on the transformer mounting screws and a thin layer of rubber on the bottom of the unit allowed me to test fit the chassis top on with no issues.I was wondering if having the large caps on the Antipole where they are so close to touching the chassis bottom is a potential issue/problem ? The Antipole just fits on the partition height wise or I would have raised it . When I got the NABU surplus case I grabbed a sheet of amplifier isolation rubber for a buck so I could add that if needed.I soldered the chip to the PCB after lining it up on a flat surface with the heat sink but now I wonder if my wood workbench top wasn't perfectly flat as the chip in the case only matches up to the sink on the top third. The chip isn't perfectly perpendicular to the sink surface or I drilled and tapped the mounting hole at a slight angle.Might have to desolder and raise the sink with a sheet of something so the mounting screw for the chip lines up properly.
I never thought of tapping with my drill press turning by hand , that would have made the non perpindicular issue go away. Going off the path just a small amount on the heat sink mounting hole made it a problem.
