This should be arriving in Indonesia some time soon along with a PSU, heatsink, and transformer. It's replacing a F5 that just makes too much heat.
Why would you use thermal paste during the fitting process on the chip? I don't follow.
I like a little worklight. Also useful is one of these for cleaning the tip of the soldering iron. For solder I recommend something sized for electronics and not speakers. I've been using Kester 44, the same roll, for years (the label on mine is ancient and unreadable) But you could spring for some Cardas solder too, if you want. Lastly a fine tip is needed. The big fatties won't work! The most important thing is patients. Make sure the spot is heated so the solder forms on the vias hole on the PCB board as well as the component. If the component got pretty warm during the process start on another one and come back to it. Sometimes on the Antipole it may be easier to do the little EPCOS caps from the top.Soldering heat for the amp board is pretty standard, approximately 750-775F/400-412C. For the Antipole board with the snap caps and CMC you can run hotter, like 850F/454C, but make very sure you're contacting the PCB board and not just the component. This is all pretty standard stuff.
