Folsom's great little 7297 Chip Amp
Folsom
Re: Folsom's great little 7297 Chip Amp
« Reply #1260 on: 2 Nov 2019, 10:04 pm »
uncola
« Reply #1261 on: 15 Mar 2020, 02:52 pm »
Might be a dumb question, but if I build active 3 way speakers with a DSP crossover, will this amp handle a chinese clone bg  neo3 pdr?  it's 4 ohms nominal and I know this amp is for 8 ohm speakers.. but tweeters don't use much power right?
Folsom
« Reply #1262 on: 15 Mar 2020, 03:13 pm »
Incorrect, it works fine with 4 and 8ohm. 4ohm gets 120w!
Tweeters do not use as much power as woofer.
Dhananjeyan
« Reply #1263 on: 16 Mar 2020, 04:16 pm »
Hey I was just wondering where can I buy all the parts from or is there a kit I can just buy?
Thank you
Folsom
« Reply #1264 on: 16 Mar 2020, 07:23 pm »
Email me at [email protected]. The parts are all in the BOM, easy to order off of Mouser.
uncola
« Reply #1265 on: 13 Apr 2020, 06:20 am »
another dumb question about the 7297.. if I only connect one speaker because I'm only testing one speaker.. it doesn't break the amp does it?
pocomo
« Reply #1266 on: 13 Apr 2020, 01:04 pm »
Not in my experience, you should be fine.
Folsom
« Reply #1267 on: 13 Apr 2020, 04:15 pm »
Correct
rajacat
  • Washington State
« Reply #1268 on: 13 Apr 2020, 05:24 pm »
Hi Folsum,
I'd like to order one kit.
...Roy
feelswatt
« Reply #1269 on: 11 May 2020, 03:05 pm »
These look awesome, is anyone offering a build service for those of us who aren't amp builders?
ksbruce
« Reply #1270 on: 11 May 2020, 04:20 pm »
I'd be interested too!
Batman Basmati
  • I do what I please, and I do it with ease.
« Reply #1271 on: 11 May 2020, 04:36 pm »
Correct
Sometimes I wonder if people are hired by advertising firms to post.
That was a quote too.
Folsom
« Reply #1272 on: 11 May 2020, 05:00 pm »
I literally have no idea what you're talking about.
But if you think Folsom has an advertising firm I think you're confused, very.
rajacat
  • Washington State
« Reply #1273 on: 11 May 2020, 05:15 pm »
:roll:
vilding
  • Musician. Audiophile on a budget.
« Reply #1274 on: 11 May 2020, 09:57 pm »
Prepped this little aluminium box on my kitchen table using a drill, handsaw and some sand paper.  :P
Now just waiting for the boards and off we go!
S Clark
« Reply #1275 on: 11 May 2020, 10:02 pm »
Cool looking box.  I started this thread 64 pages ago, and my Folsom amp is still sitting in a cigar box.   :oops:
vilding
« Reply #1276 on: 11 May 2020, 10:17 pm »
 :lol: I'd say you started in the right end, though... Great sound from a cigar box beats no sound out of any box. Bought the BOM so just waiting for the mail man to slide some green magic through my mail slot.  8) And this thread is a really nice read!
Folsom
« Reply #1277 on: 11 May 2020, 11:55 pm »
If you cut a small slot between the binding posts + and - for each channel you'll get better sound.
Batman Basmati
« Reply #1278 on: 11 May 2020, 11:56 pm »
Uh :popcorn:
mresseguie
« Reply #1279 on: 12 May 2020, 12:43 am »
My Radu Tarta built amp:
[Please note that Radu no longer builds SS amps. He's a tube guy.]
Premium Jantzen Superior Audio caps
It seems I've sold it!  8)
