0 Members and 4 Guests are viewing this topic. Read 409445 times.
Hey everyone. I am waiting on some parts to be delivered, and will need to start layout planning soon. But I am still asking questions.Up front, I appreciate all the help. 1. Can my divider wall have holes in it? I was going to order a chassis from DIYstore, and use the riser walls to separate the boards. They have a grid of holes pre drilled in them. Will those play the role of divider or do I need a solid sheet of metal for it to do it's job?2. I see some people are using terminal blocks inside the amp to connect transformers to the boards. Also, I think that maybe where some switches are attached. I wasn't aware of those and wonder if I need to try to use one.3. Can I use solid core 16 gauge wire everywhere in the amp? Or do i need to use signal wire and power supply wire that is different gauges? Also, I wouldn't know how to choose since I don't know if it matters or not.Antek transformer wiring and switch/LED questions to come later Thanks for any advice,Ben
Add the slots between the speaker binding posts, and the RCA posts.
YES. The grounds on the RCA sockets need to be able to "see" each other electrically. The results are very nice.
Yes. Just each channel, and each pair of RCA's. The slot can be relatively small.
