0 Members and 1 Guest are viewing this topic. Read 1651 times.
Looking into it I see several versions of Roku (what the difference between the stick and their box versions?)
Unless you have multiple users simultaneously streaming 1080p video, your 25Mbps Internet won't be a bottleneck and should be fine.The Roku 4 has 802.11ac Wi-Fi so you should try and take advantage of that and get an "AC" router as well. 802.11n dual band routers have both 2.4GHz and 5GHz radios while 802.11ac only works on the 5GHz band.5GHz n has better speed and less interference than 2.4GHz n, but also has less range and doesn't penetrate walls and floors as well as 2.4GHz n. The 5GHz ac band is the best of both worlds. Your ~ 125 foot distance through floor and walls is at the outer limits of range, but may work just fine. So much depends on the number, materials and construction of the floors and walls.If you're not getting enough signal at the Roku location, you may also have to add a Wi-Fi Extender to repeat the Wi-Fi signal. Another option is to use Powerline Ethernet * from the router to the Roku. Powerline Ethernet adapters create a virtual Ethernet cable through your house AC wiring and don't use Wi-Fi at all. The Roku does have a 10/100Mbps Ethernet port so it can be used with PE.* Powerline Ethernet adapters require that both outlets are on the same leg or "phase" of the electrical service panel to work.Steve
Here's a good overview of routers and a recommendation: http://thewirecutter.com/reviews/best-wi-fi-router/The recommendation: "Our pick: TP-Link Archer C7The Archer C7 is faster and can cover a large area better than many routers that cost two to three times as much. It's good for larger apartments and multiroom houses."http://www.amazon.com/TP-LINK-Archer-C7-Wireless-1300Mbps/dp/B00BUSDVBQ?psc=1&SubscriptionId=AKIAJM4NKIQGABP2PIRA&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B00BUSDVBQ&tag=thewire06-20&ascsubtag=WC29013
