Will a Current drive amp work with SMGA?
0 Members and 1 Guest are viewing this topic. Read 1118 times.
optic
« on: 11 Oct 2015, 07:29 pm »
I'm wondering if a current drive amp will work with the SMGA?
More info here. http://www.current-drive.info/
I understand some speakers are not suitable. Would this include Maggies with serial crossovers?
Optic
Davey
Re: Will a Current drive amp work with SMGA?
« Reply #1 on: 11 Oct 2015, 10:42 pm »
It would if it has enough power.  Current-drive amps are usually more suited to high-efficiency speaker systems.  (Probably not Maggies.)
The main downside is.....speaker system impedance variations translate directly into amplitude response variations.
You pretty much need transducers designed for that type of amplifier.  There are not many speakers that fit that category.
There are semantics involved here and not everyone's definition of a current-drive amplifier is the same.
Personally, I think power amplifiers should be voltage sources....not current sources.
Dave.
« Last Edit: 12 Oct 2015, 07:16 pm by Davey »
optic
« Reply #2 on: 13 Oct 2015, 02:48 am »
Thanks Davey,
I have read more about current drive amps now and agree with you. Voltage drive first choice.
