New McIntosh C1100T with my Bryston 28BSST2's? Thoughts?
0 Members and 1 Guest are viewing this topic. Read 1346 times.
tdinut
  • Joe aka Joeinid on other forums.
    • Audioshark Forum
Any thoughts on this combination? Macintosh preamps usually have under 200-250 Ohm output impedances. I am not sure about this one yet but I wonder how the pairing will sound.
  • The Demo is Everything!
    • http://www.bryston.com
Re: New McIntosh C1100T with my Bryston 28BSST2's? Thoughts?
« Reply #1 on: 8 Oct 2015, 10:24 am »
Hi
Are you concerned that a low output impedance would be problematic?
james
tdinut
    • Audioshark Forum
« Reply #2 on: 8 Oct 2015, 01:56 pm »
Hi James,
Actually I find preamps with lower output impedances work better as the ratio works in my favor.
For example, a friend has a Hegel H30 with a lower than usual input impedance and his C500T works beautifully. I love my 28's and think, for my taste, the C500T or new C1100T could be a great match as well.
I plan on keeping them until well past the warranty period  :thumb:
They truly are a home run.
Right now, I am going direct to the amps from my Lampizator Golden Gate. A simple and stunning system, IMO. I have all my other gear off to the side in my room. I feel no need to hook anything else back up. VERY unusual for me.  :oops:
« Reply #3 on: 8 Oct 2015, 02:30 pm »
Hi James,
Hi
Yes generally you want at least a 10 to 1 ratio between the output impedance of the Preamp to the input impedance of the Power amp.
james
