Vinnie,
How was the setup of those 40.2s in a room that size? Only time I have heard 40.1s, they were overloading a room at a show...
Hi roscoeiii,
But by pulling them out into the room and listening in the near field, they worked out quite well, as we eliminated some
reflection issues.
If we had room treatments on the wall behind the listening chairs, it think it would have been even better!
Compared to the 40.1s, the 40.2s received a crossover change that is supposed to tighten up the bass so it is more
room-friendly, and raise the sensitivity by a couple of dB.
I own a pair of 40.1s and have them set up quite near field in a small-medium sized (Real Traps treated) room - and they sound superb and deliver a HUGE soundstage and image unbelievably well. When I get a change I need to draw out a layout diagram to show
how I placed them. I listen late, turn out the lights, and definitely get the YOU-ARE-THERE effect and draws me in and keeps me
staying up late - too late many times!
I found this link a while back, and I have mine set up not that much differently in terms of separation of the speakers and distance to my ears, but I have more space behind the speakers than this fellow:
http://www.whatsbestforum.com/showthread.php?886-Near-Field-Listening-Acquired-Taste-or-Proper-ParadigmIt is relevant to note that Harbeths are actually designed for near field listening (e.g. studio consoles), and the integration
between the drivers is as good as I have ever heard. As mentioned in the link above, you can have your head 2 feet from them
and still not hear the drivers acting separately - the coherency is striking! I find this to be true of all their models, but it most impressive
(for me) with the 40.1 / 40.2 since they are a three-way design!
My experience tells me that the room is at least 50% of what you are hearing, so the more you take it out of the equation (room treatments, listening nearfield to "hear less" of the room, etc), the better the results. It's well worth taking the time to play with the dial in! Of course this is true with any speaker you use...
All the best
Vinnie
