GIK Acoustics NEW Alpha Wood Series
0 Members and 1 Guest are viewing this topic. Read 30394 times.
gregfisk
Re: GIK Acoustics NEW Alpha Wood Series
« Reply #80 on: 5 Feb 2016, 04:36 pm »
Glen,
Do the Alpha series and the Q7d Diffusers match in wood, color and finish?
Also, Could you explain the performance difference between the Tri Traps with the Scatter Plate on the inside and the Tri Traps with the Alpha series type add on outer scatter plate/diffusers?
Performance is more important than appearance for the Tri Traps so I'm wondering which is the better way to go, looks aside?
Greg
Hi Glen,
Could you answer this question I posted above?
Greg
Glenn Kuras
« Reply #81 on: 5 Feb 2016, 04:58 pm »
Hey Greg,
Sorry about that. Totally missed your questions.
Yes, but we changed the blond on the Q7D about 4 months ago, so if you have one later then that it might be just a tad off.
The Tri Trap with the Scatter plate how wider spacing in the plate so you get a bit more diffusion/scattering with the Alpha Corner Trap.
For sure the Alpha Corner is the best out of the Tri Trap with or without the Scatter Plate.
gregfisk
« Reply #82 on: 5 Feb 2016, 06:56 pm »
Hey Greg,
No Problem Glenn,
Thanks for the answers, I'll probably be ordering them all at once so the wood should match up fine.
Greg
