FS: Dayton Audio 2 channel amp - $50, like new
0 Members and 1 Guest are viewing this topic. Read 956 times.
mr_bill
« on: 28 Sep 2015, 03:05 pm »
Here's the link - as new.  Needed for a short term only and has less than 5 hours on it. Worked perfectly.
For sale at $50 plus shipping.  New $99.
Paypal or check for payment.  I have perfect feedback on Audiogon.
Bill
Here's all the info:
http://www.parts-express.com/dayton-audio-apa100-class-ab-stereo-amplifier-60-wpc--300-590
Dayton Audio APA100 Class AB Stereo Amplifier 60 WPC
The Dayton Audio APA100 high fidelity power amplifier switches sources and powers on (in auto-on mode) automatically when a source signal is detected. Two-sources, two-channels, and Class AB topology make Dayton Audio's APA100 amplifier the heavyweight in its class. The APA100 features two pairs of RCA line level inputs and a loop-out from the second source to feed additional zones, receivers, or other devices. Use the APA100 for additional power when connected to a multi-zone audio system, or by itself to power a stereo speaker system.
The APA100 is rated at 75 watts RMS per channel into 4 ohms, and 60 watts RMS per channel into 8 ohms. In bridged mono mode, both amplifier channels are combined for high-power monaural output. The amplifier is rated at 160 watts RMS into a single 8 ohm load when bridged. Each amplifier output channel incorporates robust protection circuitry for reliability and safety.
Specifications: • Output power: 60 watts RMS @ 8 ohms, 75 watts RMS @ 4 ohms, 160 watts RMS @ 8 ohms (minimum impedance) bridged mono • Total harmonic distortion: <1.0% @ 1 kHz • Signal to noise ratio: 100 dB, A-weighted • Frequency response: 10-30,000 Hz +0.0 dB/-3.0 dB • Input sensitivity: 900 mV (50 watts @ 8 ohms) • Crosstalk: >70 dB @ 1,000 Hz • Power: 120 VAC, 60 Hz, 4.2A • Dimensions: 16.5" W x 8" D x 2.5" H.
Charles Xavier
Re: FS: Dayton Audio 2 channel amp - $50, like new
« Reply #1 on: 28 Sep 2015, 05:20 pm »
Geez great deal. Im pissed because I just ordered a refurbed receiver for a second zone for 270.00
