0 Members and 1 Guest are viewing this topic. Read 12020 times.
The article I posted is how I go between libraries on my Mac Mini, I have no problems. How much storage does your iTunes library take up?
If you have an exact copy of that library and the old drive fails, you would simply replace that drive with the backup drive and point to the new drive. Should be pretty simple
Currently I have the split file system where the media in on the external HD and the library files are on the computer. Should I have them combined on my external HD before trying to set this up?
I missed this earlier and believe this to be your issue or question to the problem. Why do you keep the Library portion on the computer? What happens when the main HDD crashes?
I'm not sure I am following you on the file paths to the original HD. If you copy the entire iTunes folder that currently has everything you need and put that on another HDD, then point iTunes to the copy everything should work. Is that what you are asking? If yes, I can test it on my Mac Mini at home. I have a small library on the local drive and can move it to a USB drive and see how it goes.
So if you use the mirrored RAID 1 drive as a standalone drive then you just need to make sure that the volume name is the same as the current volume name.
You can always name the volume whatever you want in Disk Utility. Glad it is all sorted. Do you backup your Mac Mini? Maybe with time machine?
It looks like a nice back-up program, but I don't think it will do what I need as well as RAID 1 system would. I may get a perfect back-up of what is existing, but if my media HD fails, that back-up of media would be on a drive that the iTunes library does not point to and so would not be recognized.
Your are correct that the filepath for each song file is hard coded in the iTunes Library.itl database file. If the replacement hardrive copy is named with the exact same volume name, then it will work seamlessly. If it has a different volume name, iTunes will not find the files. You can inspect this path by performing a Get Info command and noting the path on the File tab.There is no way to "point" iTunes to a new location as the iTunes Media Folder Location only will affect newly added files, as you've noted. You can move a library by entering the new media folder location AND Consolidating Files, but that involves time consuming copying of all the files in the library.
If you have "Keep iTunes folder organised" and "Copy file to iTunes Media Library" checked, then if you move the (whole) library and open iTunes with Option key, and select the new library location, iTunes updates the paths.That's certainly seems to be what it does anyway (just tried it).
