0 Members and 1 Guest are viewing this topic. Read 27659 times.
Hi Guys,In the market for a audio rack...a budget one. I intend to use some footers to couple components to rack shelves instead of just plonking components on the rack. My question is...would it be best to look for a rack with shelves made of...1) solid wood...eg...maple or even carbonized bamboo2) MDF3) Doesn't matter...chipboard would work just fine.Let's assume that the above options are of equal thickness and racks are of equal rigidity. In the case of solid wood...would choice of wood contribute to SQ (tone)? I have been hearing that certain woods can contribute a certain tone to overall presentation. I am thinking of a softer wood than maple or carbonized bamboo to achieve my goal...a more organic tone. Or would a harder wood be a step in the right direction? Anyone tried thick plywood?Thanks.
In 40+ years at this the only racks I've ever heard was a solid rack (foot falls from a turntable on a very soft floor) or replacement of my small Ikea rack with the shelf on the floor that allowed the soundstage to fill the entire front of the room. In my experience racks/gear block the soundstage if put between the speakers.
In 40+ years at this the only racks I've ever heard was a solid rack (foot falls from a turntable on a very soft floor) or replacement of my small Ikea rack with the shelf on the floor that allowed the soundstage to fill the entire front of the room. In my experience racks/gear block the soundstage if put between the speakers.BTW this is the Cheap & Cheerful circle, so racks should be very cheap. Mapleshade isn't my style but Timbernation seems nice. Neither fit this circle's guidelines.
What the heck do neither fit the circles guidelines ?
Cheap and Cheerful budgetary guidelines: $1,000 in-room system cap (plus $200 wiggle room), $350 cap per component. DIY allowed.
Chunks of kitchen countertop on cinder blocks.
Thanks Guys for all your feedback. Really appreciate it. I am wondering why maple is choice of solid wood for most manufacturers. Does anyone know? Cost and availability driven?
