0 Members and 1 Guest are viewing this topic. Read 29624 times.
Evan,It seems to me either option you're considering is a project. You must really want that SME ? You're willing to spend an additional $400 and probably a motor ($?). Who does the work VPI ? Have a speed controller? If not you're up to an additional minimum $1.3K ?? Tell you the truth, I've only heard the SME V in a couple of set-ups where I liked it. You never know till you try, but the deal isn't looking so good anymore. I think you need to figure out your objective, mono or new top dog player. I think the answer lies in your desire to upgrade, in which case I don't know if the MKIV is an upgrade. Seriously, maybe it could be, but you could also buy the arm by itself. The Sunnydaze approach makes sense if you measure spindle to mounting hole accurately. You wouldn't need that elevation and it could be simpler. You could get a Jelco 750L 12", or any number of appropriate used arms. There's a JVC UA7082 12" on epay:http://www.ebay.com/itm/321881995735?rmvSB=trueThis one is a killer. With a Zero you'd probably need pampers. You ever drool over something and it turned out to be not only a PIA, but a disappointment? There will always be used SME's, but what's the value of a used HW19 upgraded to a MKIV ?neo
I also like the idea of a longer (12") tonearm, which could work if I adopted your outrigger approach.Evan
Unless you prefer a 12, it's not required as I'm pretty sure shorter arms can be successfully mounted alongside your WTT. I have a Townshend Rock 3. Like your WT, it has a traditional plinth and its overall dimensions seem quite similar.Note how close the platter is to left plinth edge, just like yours. This is where I set up my platform. Outboard to the Rock I've been able to mount an Origin Live Encounter, Hadcock 242, and Jelco 750E. The mount distances are 223mm, 226mm, and 240mm respectively. The Jelco is the only true 10 incher, the other two are 'tweeners.In the 2nd pic the ruler shows that maybe even a typical 9 incher (212mm mount distance) is possible?Now, if you wanna mount in the more traditional locations (ie, the corners), then maybe a 12" is required as the plinth precludes getting the platform close enough for shorter arms.To account for varying platter heights, I achieve the correct arm platform height by simply adding / subtracting wooden blocks and using different length aluminum spacers (under the round arm mounting disk).
Neo,Not sure why I'm still considering the VPI. Part of it is that I've always kinda wanted a VPI (like our original poster GentleBender), and an SME V, and the price is such that I could come out whole on just the arm.A couple of the older 'tables you linked seem really expensive, but then I lost touch of analog from the mid-80s to the late 90s so maybe I don't appreciate them. I've also toyed with getting a Lenco or an Empire which could be a good choice for a decent mono cartridge. I came across a Fat Boy, which would be an upgrade to my WTT for stereo, but now I'm just babbling.
Neo,What would you recommend for someone that wants a simple, yet refined turntable? I want a table that requires little maintenance and tinkering to sound good. I am afraid of DD due to aging electronics that I would be unable to repair. I play stereo and hope not to fall too far into this audio hobby. So many options! I like that the VPI has a separate motor so that you can replace it if problems arise, but I am open to suggestions.Bottom line is that I enjoy listening to the music and only the occasional tinkering/upgrade cartridge.
If you look old, Denon tables are awesome.
Lots of homework now! Thanks for spending the time to assist me. I have to work extra fast now to beat ACHipo.
GB,No need to strain yourself--I'm in no hurry AC
Hi Gentlebender,I'm a bit confused I thought you already had bought the VPI turntable? My advice keep it nice and simple and buy a turntable that is relatively new and you don't have to spend a lot of money on. I've spent a bundle on a Goldnote Piccolo turntable which had numerous problems and appears to be quite unreliable ie. currently on my third motor in less than 10 years (it doesn't get much use either).VPI is a USA brand so lots of parts and warranty support if you decide to go down this road.Cheers Rod
I'm really torn between the SOTA and the Oracle. Any thoughts?
