FS: Harman Kardon PA2000 Amplifier, 4x45W/ch or 2x100W/ch
0 Members and 1 Guest are viewing this topic. Read 2411 times.
djk33
The PA2000 allows you to configure as a 2x100W/ch power amplifier or add 4 channels to your existing system, perfect for adding 4 additional height channels for Dolby Atmos.  In good working condition, has a small 1/4" scratch on front face and a couple more on top of amp.
 Power Output, Normal Mode: 4 x 45 Watts @ 8 ohms, 20Hz - 20kHz, <0.07% THD, all channels driven
 Power Output, Bridged Mode: 2 x 100 Watts @ 8 ohms, 20Hz - 20kHz, <0.07% THD, all channels driven
 High Instantaneous Current Capability (HCC): 45 Amps
 Frequency Response: <1Hz - 170kHz (-3dB at 1 watt)
 Signal-to-Noise Ratio: 110dB at Rated power 45 watts
 THD/IMD: Less than 0.07% at rated output
 Power Bandwidth: <1Hz - 100kHz
 Input Impedance: 47k Ohms
 Input Sensitivity: 1 Volt for rated output
 Dimensions
 (H x W x D): 6-1/8-Inches x 17-3/8-inches x 15-3/4-Inches (155mm x 442mm x 400mm)
 Weight: 25.3 lb (11.4kg)
 Line-level outputs for daisy-chaining amplifiers
 Automatic turn-on connections
 Variable output level controls
 Gold-plated, 5-way binding-post speaker terminals
Asking $100 including shipping within USA.
djk33
Re: FS: Harman Kardon PA2000 Amplifier, 4x45W/ch or 2x100W/ch
« Reply #1 on: 28 Nov 2015, 08:29 pm »
bump
djk33
« Reply #2 on: 19 Mar 2016, 06:58 pm »
bump
