SR7 Fuse/Power selector
tunepotato
« on: 12 Sep 2015, 08:02 pm »
Paul,
I just wanted to say thanks, I received my SR7.  I am in the process of setting everything up this weekend and I have two questions before I can proceed.
1.) I noticed on the back there is a voltage selector switch, it is on the 240V, since I am in the USA do I switch this to the 120V setting?
2.) The current fuse in the unit is a 2.5A Slow blow 250V. The sticker on the back of the unit indicates that a 5A fuse is required. Should I replace the supplied fuse with a 5A Slow blow 250V fuse or 5A Slow blow 120V fuse?
Thanks again, I will wait for your response before I plug my unit in.
Brent
Paul Hynes
    • http://www.paulhynesdesign.com
Re: SR7 Fuse/Power selector
« Reply #1 on: 13 Sep 2015, 10:17 am »
Hello Brent,
Yes to both questions.
The voltage selector should be set to 120v for the USA.
A 2.5AT fuse would be fine for steady use up to full PSU rating but may suffer fatigue failure after repetitive switch-on surges so 5A would be prefered.
Regards
Paul
tunepotato
« Reply #2 on: 13 Sep 2015, 04:07 pm »
Hello Paul,
I just wrote you to your personal/business email regarding my SR7. Please read as soon as possible for it is important.
Thank You!
Brent
