YAQIN MC-13S EL34
0 Members and 1 Guest are viewing this topic. Read 4202 times.
chgolatin2
YAQIN MC-13S EL34
« on: 12 Sep 2015, 05:05 pm »
Worth the investment of $709.99?  Specs are below
Technical Details
    Brand Name: Yaqin
    Model Number: YAQIN MC-13S
    Output Wattage: 45 Watts
    Color: multi-colored
Product Description
Output Power:45W + 45W (8ohm)
Frequency Response:5Hz -- 54kHz (-2dB)
Signal/Noise Ratio: >=88dB (A)
Load impedance: 8ohm or 4ohm
Distortion:<=0.35%
Maximum Power Consumption:220W
Input sensitivity:<=200mV
Tubes: 6CA7T x 4 12AX7B x 2 12AU7 x 2
marvda1
  • freelance reviewer: The Sound Advocate
Re: YAQIN MC-13S EL34
« Reply #1 on: 12 Sep 2015, 05:56 pm »
Where are you getting it from?  You can find it cheaper. Silk audio or Canada.
chgolatin2
« Reply #2 on: 13 Sep 2015, 02:29 am »
Amazon, but that wasn't the ? lol...  How can I get it "cheaper?  I need more details on the amp, not price but I do appreciate the response~
tx2sturgis
  • Texas Panhandle
« Reply #3 on: 14 Sep 2015, 04:44 am »
Your question was "Worth the investment of $709.99?"...so that answer dealing with price is entirely in the ballpark...you didnt ask ANY questions about the amp or its specs...
tx2sturgis
  • Texas Panhandle
« Reply #4 on: 14 Sep 2015, 04:45 am »
(duplicate deleted)
chgolatin2
« Reply #5 on: 20 Sep 2015, 03:32 pm »
Was curious if anyone could give me their impression about this amp, due to its price range IMO its considered cheerful and cheap.  But then again, I ended up going for Cary Audio SLI 80 instead.   :wink:
« Reply #6 on: 20 Sep 2015, 06:17 pm »
Technical Details
    Brand Name: Yaqin
Product Description
Distortion:<=0.35%
The output power is too big to just two EL34, even in Pentode it would be around 30W.
STM output power may be around 15W RMS in Triode.
If you need 45W to your speaker take care.
At Hong Kong its cheaper, the chassis is nice.
http://www.china-hifi-audio.com/en/yaqin-tube-amp-audio-c-14/yaqin-mc-13s-tube-6ca7-t-push-pull-hifi-integrated-amplifier-p-353
« Last Edit: 21 Sep 2015, 02:17 am by FullRangeMan »
chgolatin2
« Reply #7 on: 29 Sep 2015, 11:28 pm »
At the end of the day, I ended up with a Cary Audio Integrated amp, not on the cheap side either but thank god for Audiogon   :wink:
