0 Members and 1 Guest are viewing this topic. Read 3813 times.
Hi loco11, and welcome to the forums. Have you thought about the Decware Taboo MK III? You could cover both bases as it is an excellent headphone amp and can drive speakers just as well IMO (the MK II is my main speaker amp) as long as your source/dac has a good output voltage of about 2.1v or higher.
I'll do what others does in here, and recommend Decware .Both the taboo mk3 and minitori are build for both speakers and headphone usage, decware build them so that you can plug in your cans and remove the speakercables without damaging the amp. I think you achive much better headphone quality this way. The taboo might be an extra good amp for cans, especially Audeze. I use them with my Minittori and really enjoy the result. The SET vs SEP sound I can't really tell what I prefer, but if the sound of SET is so uniqu, in terms of better, then I truly look forward to getting the SETamp I'm about to order. To be honest I believe it us nuances, and SEP sound I get with my omega speakers is truly really really good .
