SOLD: Emotiva XPA-200 stereo amp
0 Members and 1 Guest are viewing this topic. Read 1964 times.
posternutbag2000
« on: 8 Sep 2015, 12:56 am »
Purchased about 2 yrs ago as a factory refurbished unit from Emotiva to use while my Lyngdorf integrated amp was being repaired.  Used less than 50hrs and has been boxed up since.  Like new condition, no visible marks that i could find anywhere on it.  New price: $499 (plus shpping); refurbished price: $399 (plus shipping); my price: $350 (including shipping to continental US)
PM me for details/questions.  Includes original box, manuals, etc.  I accept Paypal (add $2.9%) or money orders.  Local pickup in SF would be ideal.
From Emotiva website:
What do you do when you want the incredible sound quality and features of the legendary XPA-2, but you don’t need quite as much power? We have the perfect choice, the all-new XPA-200. Equally at home powering a superb stereo system or the front channels of an audiophile surround sound system, the XPA-200 delivers 150 watts per channel into 8 ohms, or 240 watts per channel into 4 ohms of powerful, clean, audiophile grade audio power. The highly refined amplifier circuitry in the XPA-200 handles subtle details with finesse, while the hefty power supply provides plenty of dynamic power reserves for demanding source material.
Inside, the XPA-200 boasts the advanced engineering, high quality components, a heavy-duty toroidal transformer power supply, and our classic short signal path Class A/B technology. Also on tap is the transparent yet comprehensive protection circuitry you’ve come to expect from Emotiva. The new Gen2 version has also been upgraded with our new custom low-ESR power supply filter capacitors for even more stunning dynamics. Outside, you get Emotiva’s elegant new Gen2 styling, solid machined brass gold plated RCA jacks, and full-sized five-way binding posts. All the greatness of XPA, just smaller.
The XPA-200, enjoy your journey.
Specs:
    Topology: Fully discrete, dual differential, high current, short signal path Class A/B.
    Number of Channels: 2
    Power Output
    (rated power; THD < 1%):
    150 watts / channel; into 8 Ohms; both channels driven.
    240 watts / channel; into 4 ohms both channels driven).
    Rated Power Bandwidth (at rated power; 8 Ohm load): 20 Hz to 20 kHz + /- 0.045 dB.
    Minimum Recommended Load Impedance (each channel): 4 ohms (which equals one 4 ohm load or two paralleled 8 ohm loads per channel).
    Frequency Response: 10 Hz to 80 kHz (+ 0 / - 1 dB).
    THD + noise: < 0.02%
    Signal to Noise Ratio (8 Ohm load):
    > 89 dB at 1 watt (A-weighted).
    > 110 dB at rated power (A-weighted).
    Damping Factor (8 Ohm load): > 500
    Speaker Output Connections:
    Full-sized 5-way binding posts; one pair per channel x 2.
    Power Supply:
    90,000 uF of low-ESR storage capacitance.
    360 VA heavy duty toroidal transformer.
    Input sensitivity (for rated power; 8 Ohm load): 1100 mV
    Gain: 29 dB
    Input Connections: Unbalanced (RCA), Balanced (XLR); one each per channel.
    Input Impedance: 47 kOhms
    Trigger:
    Trigger Input: 5 - 20 V (AC or DC); <10 mA input current required.
    Trigger Output: 12 VDC; can drive any load up to 50 mA.
    Power Requirements: 115 VAC or 230 VAC +/- 10% @ 50 / 60 Hz (automatically detected and switched).
    Front Panel Controls and Indicators:
    Standby; push button (changes color to indicate Standby or On).
    Status LEDs (one per channel); illuminate blue for normal operation or red to indicate a fault (may be disabled by rear panel Status LED switch).
    Rear Panel Controls:
    AC Power switch; rocker switch (switches AC mains power).
    Status LEDs switch; small slide switch on left rear (disables front panel Status LEDs and dims Standby button halo lighting).
    Input selector; toggle switch (selects between balanced and unbalanced inputs).
    Protection: The XPA-200 is protected against excessive operating temperature, shorted speaker connections, ground faults, and other common fault conditions.
    Size:
    unboxed: 17" wide x 3.875" high x 19" deep
    boxed: 21 3/4" wide x 8 1/2" high x 22 1/4" deep
    Weight: 31 lbs (37 lbs boxed)
« Last Edit: 8 Oct 2015, 04:21 pm by posternutbag2000 »
posternutbag2000
Re: FS: Emotiva XPA-200 stereo amp
« Reply #1 on: 16 Sep 2015, 04:54 pm »
Price drop to $325 including shippin for a basically new amp.
PM me for details....boxed and ready to ship.
posternutbag2000
Re: SOLD: Emotiva XPA-200 stereo amp
« Reply #2 on: 8 Oct 2015, 04:21 pm »
Sold.
Thanks! :thumb:
