0 Members and 1 Guest are viewing this topic. Read 10141 times.
I recall one guy posted a long list of tube amps a couple days ago hoping to start up a thread. http://www.audiocircle.com/index.php?topic=136916.0
I would also check out the offerings from Cayin, AudioSpace and Line Magnetic.
What are your speakers, and how do you define "a little more power"?Absent that info, off the top of my head I'd recommend: PrimaLuna -- I owned the Dialogue 2 integrated......excellentRogue -- I currently own Atlas Magnum amp. Really good.Line Magnetic -- based on user comments /reviewsInspire by Dennis Had of Cary (if enough power) -- based on user comments / reviewsBuy used for best buck bang. For your $2k budget you can get something that lists up to 5 - 6k, if the piece is a bit older or discontinued.
For a lot less money and with near SET amp performance I'd consider the TPA3116 with a good tube preamp. I had a Primaluna Prologue which didn't sound nearly as good as the TPA3116.
How do you compare the Primaluna against the Rogue? I like the Cronus Magnum from Rogue, real nice unit however I haven't seen one in person or tested on. Well, what I meant by power is for the simple reason to power speakers which are inefficient or better said, need more power to be played...I currrently have a few bookshelf speakers and 2 towers called the (VR 2's) which I love and had them for years...
If you are looking for high power, there is a used Audio Reasearch VT100 MKII for sale on audiogon-https://app.audiogon.com/listings/tube-audio-research-vt-100-mkii-tube-amplifier-2015-08-31-amplifiers-92679-coto-de-caza-caI would love to have this amp.This BAT VK-200 amp is another beauty-https://app.audiogon.com/listings/tube-balanced-audio-technology-vk-200-stereo-amplifier-55-off-free-ground-shipping-1-ye-2015-08-20-amplifiers-14303-1231-niagara-falls-ny
In the case of lower sensitivity / harder to drive speakers, I think you'd be better served by the Rogue Cronus. It has better grip, torque, slam and speed than the PL. Having said that, I love the sonic direction in which the PL leans. My thing is immersion and involvement. On the right speakers, the PL can give a beautiful haunting sound. But if memory serves, the PL integrateds only offer about 40 wpc.I'd watch for a used Cronus Magnum. With KT-120's it will drive almost anything. I've seen them used for about $1500. Buy used and the risk is low. Try it in your own setting, if it doesn't work re-sell and recover all / most of your outlay.In loose general terms I'd say:PrimaLuna = plush, full, rich, warm, toney. Still plenty of detail but leans toward vintage tube.Rogue = fast, tight, dynamic. The dimensionality and touch of warmth tell you it's tubes, but it's comparatively a bit cooler. A more "modern" tube sound, if you will.I am going to check out the Primaluna, Jolida and the Rogue. I tend to lean on the plush, full, rich warm vintage tube sound. IMO is the best sound. As per my understanding Rogue uses a board and not PTP wiring, which is something more new age, or better said leaning towards the solid state but I maybe wrong...
