Dumb - 2 toasted boards in 24 hour
tortugaranger
    • Tortuga Audio
« on: 22 Aug 2015, 03:28 pm »
After literally never reversing power polarity on any preamp board over 3+ years I've managed to do so and toast 2 boards in the past 24 hours.  :duh:
Next board version will have reverse polarity protection.
Meanwhile all you DIY folks - be careful, lest you experience the snap, crackle and pop of $200+ going down the drain.
craig sawyers
Re: Dumb - 2 toasted boards in 24 hour
« Reply #1 on: 23 Aug 2015, 02:38 pm »
Been there, done that, got the badge.
Latest was my Tek 577 semiconductor curve tracer.  Tantalum bead had gone short circuit somewhere - a common problem on Tek gear of that vintage, so I pulled the (pin header) connectors on the power supply, and quickly found the problem.  Fixed it.  I then plugged the connectors back into the power supply - but got one connector one pin out.  I reckon I fried pretty much every bit silicon in the darned thing.  When the magic smoke comes out, it is very difficult to get it back in again.
Craig
Nick77
« Reply #2 on: 23 Aug 2015, 03:12 pm »
Wow, its in the air. I just changed to an Oxaide plug on my LPS and left a small dribble of solder off the hot pin. Sizzle!!
Fortunately only lost 2 resistors. PTL   :duh:
Careful people, mistakes do happen to the best of us.
Nick77
« Reply #3 on: 23 Aug 2015, 03:13 pm »
double post  :scratch:
« Last Edit: 28 Aug 2015, 05:21 pm by Nick77 »
Norbert2nd
« Reply #4 on: 28 Aug 2015, 07:14 am »
Hi Morten,
I can definitely feel with you ...
Norbert
tortugaranger
    • Tortuga Audio
« Reply #5 on: 28 Aug 2015, 02:25 pm »
Hi Morten,
Norbert
Welcome to the club that nobody hopes to join!   :thumb:
