SOLD: nCore Monoblocks
0 Members and 1 Guest are viewing this topic. Read 2052 times.
RUR
« on: 21 Aug 2015, 03:43 pm »
~2 years old and little used.  Built using the SiliconRay chassis.
I purchased the parts and then had these professionally built to drive the tweeters in an active tri-amp setup.  As you would expect, they sound terrific, but I eventually tired of the clutter associated with multiple amps and moved to a single-box solution.  Idle power draw is nil and these were built without an on/off switch, but it’s a simple mod to add one, if needed.
Asking $1,150
Located in Los Angeles, CA.  I’ll split well-packed shipment costs and transaction fees, if any.  Paypal, cashier’s or personal checks are fine but, unless I know you, I’ll likely withhold shipment until any check has cleared.
« Last Edit: 6 Sep 2015, 08:41 pm by RUR »
audio.bill
Re: FS: nCore Monoblocks
« Reply #1 on: 21 Aug 2015, 08:12 pm »
It might be helpful if you mentioned which nCore modules they use, i.e. the power rating into 8 and 4 ohms. Good luck with the sale!
RUR
« Reply #2 on: 21 Aug 2015, 10:01 pm »
Bill,
Both amps use the NC400 amp module:
http://www.hypex.nl/docs/NC400_datasheet.pdf
and the SMPS600 Power Supply:
http://www.hypex.nl/docs/SMPS600_Datasheet.pdf
RUR
« Reply #3 on: 24 Aug 2015, 04:55 pm »
Price reduced to $1,150
RUR
« Reply #4 on: 1 Sep 2015, 03:13 pm »
Weekly bump.
RUR
« Reply #5 on: 4 Sep 2015, 02:33 pm »
Sale pending.
