***SOLD*** Cullen Cables “Crossover Series” 20amp Power Cable, 4ft. * NEW *
0 Members and 1 Guest are viewing this topic. Read 1174 times.
iamjaymo
For your consideration is a brand new Cullen Cables, “Crossover Series”, 20amp power cable, 4ft. in length.  I was not much of a believer in power cables but this Cullen Cable has proved to me a difference is audibly discernible.  I had this cable connected to a power conditioner and was used for only two months - it is literally a new cable.  This cable made everything crystal clear in sound and seemed to make the black, blacker.
The 20amp end is a Hubble 320HC connector and the the other end is a cryo treated custom designed connector (see description below).  Here is a description from the Cullen Cables website:
Cullen Crossover Series Power Cable
This Power cable brings to the table the perfect blend of Silver and Copper. It is completely hand built from the ground up. I start with 3 – 12 Awg 99.99% Pure Silver Plated Copper with Teflon Dielectric. I braid the 3 wires in a way to virtually eliminate any Noise present. Then the wires are shielded with a 100% coverage Tinned Copper Shield Braid. This makes for a drop dead Silent Power Cable. After that the shielded wires are wrapped with a Teflon Wrap and then for a great cosmetic look covered with Black Techflex Sleeving.
The Perfect blend of Silver and Copper makes for a very tube like sound. But Not Bright or Dull. You will find yourself playing a track over and over again because you hear sounds that were not previously identifiable. Available in 15 amp or 20 amp Terminations. (20 Amp IEC connectors is a Hubbell 320HC)
Power Cable Features
Military Spec Wire
12 Awg 99.99% Pure Silver Plated Wires (Line, Neutral, and Ground)
Teflon Dielectric which provides an extremely Quick and accurate Power Cable
Available with a 15 Amp or 20 Amp IEC
100% Shield Braid Coverage
Super Flexible
Completely Hand built from the Ground up
Made in The USA!
Connectors
18k Platinum plating over 99.99% OFC Solid Red Copper On both IEC and Plug
Cryo Treated for 48 Hours at -192 degrees
CONUS sale only. Paypal only, gift preferred.  MSRP for this cables was $218.  I have sold many, many times on AC and have only positive feedback.
« Last Edit: 6 Oct 2015, 09:23 pm by iamjaymo »
iamjaymo
How about $85 shipped.
iamjaymo
Bump for a truly great cable at a fantastic price!
iamjaymo
Sale pending...
iamjaymo
Sold, thanks!
