0 Members and 1 Guest are viewing this topic. Read 11539 times.
Still thinking on my options for upgrading from my Studio-20 speakers on my 2.0 ch system. I'd love SongTowers but, I've decided that SongBirds may be a better choice since we plan on selling the house to downsize next year. We may rent for awhile so, I expect our listening space will be smaller.I currently have Studio-20s on stands. The SongBirds seem much more compact and would probably sound better.Then I started thinking ... maybe still consider bookshelf speakers. Would SongSurrounds be a better option than SongBirds? .... or even CAOW1s?My budget is < $1800.
Supercharged Songtowers are a little smaller than the songtower.
Hi,If it was me I would go for Songtowers. Jim occasionally sells refurbished Songtowers for $1695 which might be something to consider. Cheers Rod
The SongBirds take up the same amount of floor space as a set of bookshelves with stands, but have much better bass extension due to the transmission lines cabinets. In a small listening room like mine, they are the perfect solution. It's said they sound very much like the SongTowers, which just makes sense. The only issue with them is their lower sensitivity, so you'll need a little more power to drive them. I use 100 watts/ch in my room and it works great.Cornelis
Cornelis, How big is your room? I really like the ST's but they are too tall for my living room (18x19, see attached picture) . I worry that the Songbirds would not be powerful enough for the room. I have the ascend sierra 2 right now- but my daughter has already knocked one over. They are fantastic speakers. While the ST's, I expect are going to be better, I don't know about the Songbirds.-Branon
