0 Members and 1 Guest are viewing this topic. Read 8689 times.
The Peachtree Nova series (65SE/125SE/220SE) currently sells from $800 - $1600, so I assume that's your price range.Depending on the number and type of digital inputs needed, the NuPrime IDA-8 (1-USB, 1-RCA Coax, 1-Optical TOSLINK) @ $995 is a nice integrated with DAC.Steve
DAC's and technology are moving too fast to restrict yourself to an integrated and DAC included.
You might consider an Exposure 3010s2d integrated with a DAC card. I have one, but with a MM phono card, and absolutely love it--beautiful texture and corporality that some call tube-like. A used 3010s2d without either a phono card or DAC card would be just a bit above your budget (when they come onto the market, which is not often), and you would then need to purchase the DAC card separately and install it (which should be fairly easy). But I think you would find the result very satisfying.
I would also consider the Cambridge Audio CXA81 if you do not need 200wpc. I have not heard it but What HiFi gave it an excellent write up. I like Cambridge Audio gear. I use to own the 851c CDP. Also, the newer PeachTree gear is supposed to sound very good. I think they have a new owner and stepped things up a bit if I am not mistaken.https://www.whathifi.com/us/reviews/cambridge-audio-cxa81
