VALJE - Another IKEA vinyl storage idea. Thought?
0 Members and 1 Guest are viewing this topic. Read 18519 times.
CSI
Re: VALJE - Another IKEA vinyl storage idea. Thought?
« Reply #20 on: 18 Aug 2015, 07:01 pm »
I have about 1800 LP's stored in Kallax shelving from IKEA. It is fairly cheap and if you anchor it to the back wall no worries about depth.
nnck
  • Music Collector, Audiophile, in that order :)
« Reply #21 on: 19 Aug 2015, 12:41 am »
I just stack these up and they are rock solid since they are essentially double walled. You can arrange them any way you want.  At $19.49 a piece,  6 of them is not too much over VALJE.
http://www.target.com/p/way-basics-eco-modern-storage-cube-espresso-wood-grain/-/A-12130598#prodSlot=medium_1_27
Woodsyi- it looks like the dimensions of the item you linked to would not even be able to hold a record sleeve. I thought LP sleeves were about 12.25" square. 'Compartment' dimensions wouldnt even be able to accommodate that.
"Dimensions: 12.8 " H x 13.4 " W x 11.2 " D
Weight: 4.7 Lb.
Compartment Dimensions: 11.2 " H x 11.8 " W x 11.2 " D"
SteveRB
« Reply #22 on: 19 Aug 2015, 06:17 pm »
My Kallax shelf.
I used PL400 on all the joints when putting it together. Also added a 1/2" plywood back and screwed to the wall. Hold well over 2000 lps. Hopefully if the big one hits, they don't crush me in my sleep.
vinyl_guy
« Reply #23 on: 19 Aug 2015, 06:36 pm »
Steve,
what is PL400?
SteveRB
« Reply #24 on: 19 Aug 2015, 06:39 pm »
Construction adhesive: super thick glue.
It is very strong, and capable of bridging a 1/4" gap... Ikea tolerances.
woodsyi
« Reply #25 on: 20 Aug 2015, 12:02 pm »
Weight: 4.7 Lb.
I don't know about the compartment dimension values.
This is what I have and records, even boxed sets, fit fine.
Here is a closer up picture.
woodsyi
« Reply #26 on: 20 Aug 2015, 12:13 pm »
Actually those a the 2 shelf versions.
Single cubes are stacked up here.
« Reply #27 on: 20 Aug 2015, 04:15 pm »
I would not stack. No way of securing them without causing problems.
AllynW
« Reply #28 on: 27 Aug 2015, 02:21 pm »
The link below will take you to Walmart. It is what I use to store my LP's.  It is priced at $68.00 for an 8 bay unit and comes in multiple colors and sizes. It may be worth a look for folks who don't have a Ikea near by.
http://www.walmart.com/ip/Better-Homes-and-Gardens-8-Cube-Organizer-Multiple-Colors/29741111
woodsyi
« Reply #29 on: 27 Aug 2015, 02:34 pm »
They are modular.  Wooden pegs come with for stacking.  You know, pegs in the hole, line up the top one, slot it in, repeat...
I have had no problems but then stacking could be a challenge to some. :duh:
« Reply #30 on: 27 Aug 2015, 02:59 pm »
I didn't know they had pegs..
All you had to do is say so before.
« Reply #31 on: 27 Aug 2015, 03:01 pm »
How does that stack up to the Expedit?
nnck
« Reply #32 on: 27 Aug 2015, 11:29 pm »
Woodsyi- WOuld you be able to measure the dimensions of your cubes (esp the inner compartment dimensions). They do look like a nice option, but I can't get over the fact that the inner dimensions of the product link you sent out would not be able to fit an LP!
Weight: 4.7 Lb.
woodsyi
« Reply #33 on: 28 Aug 2015, 02:41 pm »
I will measure it and report back, probably after the 3 day hiatus.
