Lost Well Tempered reference arm template
0 Members and 1 Guest are viewing this topic. Read 1898 times.
daveyonthecoast
« on: 15 Aug 2015, 02:18 am »
Hello friends
Can some one tell me is the Rerernce, arm exatley 9", and what would the overhang, should be in lenth or degrees
I have set it up, with a mate, using a universal protractor, but can't seem to get the overhang right, would this cause the mistracking of the cartridge(making it skip, and or repeat it self), any ideas anyone??
many kind thanks
Regards
David
gagamut
Re: Lost Well Tempered reference arm template
« Reply #1 on: 27 Aug 2015, 01:43 am »
Hi David,
i can copy a original Well tempered protractor to you :D
