Continuosly Adjustable Stands (NOT LECTERNS)
0 Members and 1 Guest are viewing this topic. Read 5643 times.
dlparker
  • Dave Parker - KC, MO
« on: 3 Aug 2015, 09:55 pm »
I've chosen this circle to post in because my question seems to fit best here.
Does anyone know of any comercially available continuously adjustable speaker stands for home use? I've searched this site
and also on google and there are plenty of fixed increment adjustment audio speaker stands available, but the only continuously
adjustable 'speaker' stands I've found are lecterns.
jk@home
Re: Continuosly Adjustable Stands (NOT LECTERNS)
« Reply #1 on: 3 Aug 2015, 11:13 pm »
Something like this (or the other JTL Audio stands)? Looks rich...
http://www.monoandstereo.com/2015/01/jtl-audio-ef3-stands-new.html
Phil A
Phil A
dlparker
« Reply #4 on: 4 Aug 2015, 12:17 am »
Rich as in "I'll bet I could unload a couple of those 250' yachts that I don't use any more and buy these puppies!'? Just out of curiosity I tried to find the price,
but..
dlparker
« Reply #5 on: 4 Aug 2015, 12:21 am »
How about these?  http://vintageking.com/sound-anchor-motor-adjustable-start-speaker-stand
Now THIS product line I'm checking out to see what their absolute bottom-of-the-line stuff might run for..
dlparker
« Reply #6 on: 4 Aug 2015, 12:33 am »
There's also stuff like - http://www.amazon.com/VideoSecu-Adjustable-Height-Speaker-Stands/dp/B000X6DCK6
Right!! Now I remember running across this company on one of my trips either into or out of the internet
rabbit hole. I've got so many ideas running through whatever is left of my mind (assuming I ever had one)
that I'm not surprised that something I'd already stumbled across would have escaped again.
This could be the one!
Thanks Phil!
jk@home
« Reply #7 on: 4 Aug 2015, 12:35 am »
but..
LOL, I guess if you have to ask, then you can't afford them.  :lol:
« Reply #8 on: 4 Aug 2015, 12:40 am »
I have a pair of adjustable stands that I bought years ago from Ascend Acoustics.  Nothing special: black painted heavy gauge metal, one square hollow shaft roughly slides inside another with a nut to tighten at a range of heights, about $100/pair as I recall, but no longer available.  Small speaker wires can fit inside.  The shafts are tilted backwards.  Holes in each base allows spikes to be added.
Phil A
« Reply #9 on: 4 Aug 2015, 12:44 am »
Thanks Phil!
You're welcome - was looking at speakers stands all over Amazon anyway to for use early next year in converting the in-ceiling surrounds as overhead channels for Atmos (when I get capability) and I have the new side surrounds awaiting the stands.
dlparker
« Reply #10 on: 4 Aug 2015, 01:24 am »
I checked out their  website. I know the company by reputation only, but the Sierra 1 was one I'd considered previously. These are the SP-30s, right? The website doesn't say anything about them being adjustable, but given they're not available anyway..
Right now the VideoSecu stands look like the most promising in terms of budget and flexibility..
raddar
« Reply #11 on: 4 Aug 2015, 03:44 pm »
look for some Core Audio Design Speaker Stands. I found a pair used.
« Reply #12 on: 4 Aug 2015, 05:40 pm »
No, the ones I bought are no longer available.
Phil A
« Reply #13 on: 4 Aug 2015, 06:13 pm »
Yes - seen those - they are nice - http://coreaudiodesigns.com/products/speaker-stands/
dlparker
« Reply #14 on: 4 Aug 2015, 07:20 pm »
Beautiful!
mamba315
« Reply #15 on: 5 Aug 2015, 06:21 am »
I have Reference 3A speaker stands.  Continuously adjustable from 19-30".  I combine them with the Isoacoustic monitor supports, which have several tilt and height options as well.  These are a great combo.  Never had a situation they didn't allow me to optimize.
http://www.reference3a.com/stands.html
http://www.isoacoustics.com/index.php
Phil A
« Reply #16 on: 5 Aug 2015, 12:09 pm »
The Reference 3As are nice - forgot about them.  Someone I know (and was over his place about a week and a half ago ago admiring them while we swapped preamps in the system).
« Reply #17 on: 10 Aug 2015, 03:47 am »
Zaor SE Munro Studio Monitor Stands (500 British pounds), shipping across the pond might be a problem.   :(
