Daedalus Audio Isolation devices
0 Members and 2 Guests are viewing this topic. Read 62102 times.
Daedalus Audio
Re: Daedalus Audio Isolation devices
« Reply #100 on: 16 Jun 2016, 12:21 am »
Lou-
Is there any plan to offer the DiD in black?  Just some black anodize.   ;)
We have looked into that but because of the design and using wood parts it would be  more expensive and I doubt people will pay for that option.
Good question though.....
thanks,
lou
patonycam
« Reply #101 on: 22 Jun 2016, 09:25 pm »
Hey Lou:
Are going to be at Capital Audiofest 2016?  Mr. Jamison will be looking for you.
Tony C
Daedalus Audio
« Reply #102 on: 23 Jun 2016, 01:47 am »
Hey Lou:
Tony C
Of course!!! one of my very favorite shows!
will be in room 323 with Border Patrol and Triode also will have a table in the Marketplace with Modwrights new Tryst headphone amp doing demos of the DiDs
audiotom
  • Ground control to Major Tom
    • for everything music
« Reply #103 on: 27 Jun 2016, 04:27 pm »
I met someone new at our New Orleans audiophile club meeting that I was hosting at my house last Thursday
He was very complimentary of my Ulysses and asked a number of questions
It turned out he has two sets of three DIDS
He also has a Mod-wright modded OPPO 105
wow
zybar
« Reply #104 on: 17 Jul 2016, 04:23 pm »
thanks,
lou
Lou,
Another vote for black.
I grabbed a set of DiD's from a friend who had an extra set and they sound great!
However, I really would love to have them in black.
Here is a pic:
George
Daedalus Audio
« Reply #105 on: 18 Jul 2016, 03:26 am »
Lou,
Here is a pic:
OK but as I said it will cost more, not sure how much but it may be substantial.
How much extra would you pay for black?
curious....
 :scratch:
and thanks much for tryi8ng them :thumb:  glad you like em. thanks!
George
zybar
« Reply #106 on: 18 Jul 2016, 12:35 pm »
Lou,
What does substantial mean?
If substantial meant double - no, I wouldn't pay that kind of premium.
While the DiD's are excellent and definitely improve the sound, they are already a good sized investment.
George
audioguy213
« Reply #107 on: 18 Jul 2016, 12:47 pm »
what about a hollow sleeve of something black the DiD would sit within
that could be cheaply added and would provide the aesthetics sought.
Send me 12 units to test and I will write a review on AC.
jtwrace
    • TIPP YouTube Channel
« Reply #108 on: 18 Jul 2016, 01:26 pm »
Lou,
George
It's not substantial to anodize.  Maybe $10 - $20 each depending on quantity.
Daedalus Audio
« Reply #109 on: 18 Jul 2016, 04:38 pm »
It all gets complicated when you mix wood and metal....
can't anodize after the wood is installed and may scratch the anodize when installing the wood ...bit of a catch-22 :scratch:
I may work out something but it would likely raise the cost from $160ea to $200-$250 ea.
(cost of anodize, additional labor, QC and 'lost/scratched' parts etc)
If enough people think that would be worth the additional $ then I can look into it. fair enough? :)
btw, There is no reason someone who wants them black or purple etc can't paint them...    :wink:
zybar
« Reply #110 on: 18 Jul 2016, 04:58 pm »
Thanks for the post Lou.
That is indeed a substantial cost increase and I would really need to think about it.
George
Daedalus Audio
« Reply #111 on: 18 Jul 2016, 05:10 pm »
George
thanks for understanding.  I really try to keep prices fair but I just can't lose money ....
If it were just the cost of anodize I would have those done in a heartbeat but it isn't that easy.
I'll look into this more and see if we can come up with a better option, I still doubt that anything can be done for less than an extra $40 each. remember this is a dealer item so their margin is reflected in the retail.
OzarkTom
« Reply #112 on: 18 Jul 2016, 05:40 pm »
A $4 can of spray paint from Wally World would work.
audioguy213
« Reply #113 on: 18 Jul 2016, 05:43 pm »
How about you guys apply the paint, a nice even layer of flat black on the outer part only, for a nominal upcharge?
jtwrace
« Reply #114 on: 18 Jul 2016, 05:51 pm »
Should be easy enough to install the wood after with the proper press fit clearance.  Not really a big deal.
zybar
« Reply #115 on: 18 Jul 2016, 05:51 pm »
Silly question on painting...
Do I need to prime them, or do I just spray away?
Would I just use Rustoleum  (or equivalent from HD)?
George
Daedalus Audio
« Reply #116 on: 18 Jul 2016, 06:01 pm »
George
Good questions.
use a metal primer first, then paint. Rustoleum etc should be fine, you could even use a pebble finish etc?
I would tape off the bottom and the inside though.
thanks,
lou
rajacat
  • Washington State
« Reply #117 on: 18 Jul 2016, 06:02 pm »
George
Aluminum generally needs to be prepped with an etching/cleaning solution such as  Phosphoric Acid based Alumiprep 33. http://www.merrittsupply.com/products/29493-alumiprep-33-aluminum-cleaner-conditioner.aspx.
Aluminum doesn't hold paint very well. It needs etching to get a grip.
jriggy
« Reply #118 on: 18 Jul 2016, 06:04 pm »
I was afraid to say it!  :lol:
I there a 'sticks to anything" high quality Krylon spray can that would work well?
Daedalus Audio
« Reply #119 on: 18 Jul 2016, 06:14 pm »
OK, I need a show of hands...
Is it worth an extra $40 each to have them in black?
I'm guessing that is the minimum it will have to be (hopefully I can find a way to make it less).
I have to hear that enough people would pay that much extra to get them in black.....
thanks,
lou
