0 Members and 1 Guest are viewing this topic. Read 13657 times.
My current plan is to experiment with height when my new Super Alnico 6 Monitors arrive and then when I know what the best height is, to spring for a pair of the A & M Fabrication four post steel stands. I've exchanged a few emails with the proprietors and they seem very responsive and courteous; always a good sign.
These MDF stands for my Omega Bipoles (BTW they are for sale ) were easy to build and cheap too. The good thing about these stands is that they're almost full width and are flush with the baffles thereby providing the "beard" effect which extends the bass output of the drivers. They can also be filled with sand for mass loading.
Rajacat,Having never built anything like your stands, how did you go about it? Are they simply glued together? Where do you get those kinds of materials? Etc, etc...
JLM's suggestions will get you there. I shouldn't assume that everybody has a tablesaw in their garage. You could use plywood instead of MDF; its a lot less messy. However, ply is more difficult to finish. I used a router, tablesaw, a few clamps, yellow glue and a brad nailer. I simply cut the wood to size, applied glue to the edges, clamped a butt joint in position and used the brad nailer to secure the joint. I did each butt joint one by one until the box was complete. The brads act as clamps. The glue provides the strength. Carpenter's glue is very strong. No screws needed so there aren't a lot of sizable holes to fill. The base doesn't necessarily require a router. You could get by with judicious use of sandpaper. No need for blocks in the corners. Light filling will be needed.
Some live in a small apartment with no garage. The corner blocking makes for stronger joints than butt joints and easier to clamp in position. Yep a hand planer, wood file, or lots of sanding could replace a router.
Not sure why a $300 USD manufactured stand would be any better than a much cheaper custom built, shot/sand filled MDF stand.
I am very sorry to report that the folks at A & M Custom Speaker Stands are taking a production hiatus. I was about to call them and talk to them about making a set of stands for my Super Alnico monitors when I saw a message posted on their homepage saying that both members of the father-son team that makes these speaker stands has been diagnosed with cancer so they are shutting down until October 1. Too bad! I wish them both well!
Check these out, especially the V series.http://www.webmall2000.net/storage/mhv_stand.asp[/quoteHi, spence,Thank you for this tip. Have you ever actually seen or used one of these? I'm a little concerned that the top plate is quite small for a big monitor like the Super Alnico, but the price is certainly great.
