Tried to buy a new camera, then I needed a new computer and then.....
0 Members and 1 Guest are viewing this topic. Read 10525 times.
Wayner
DSC-W830
Phil A
Which Sony camera was it?  I use a Sony camera (A7r), but it never needed Sony software of any kind installed on my computer, as I just take out the SD card and insert it into my computer or use the cable to move files to my computer.
I have a Sony camera that came with software that stopped working not long after the install (Windows 7 Pro).  Like you, I just remove the SD card as well
Listens2tubes
My Sony DCS-H50 uses the Sony Memory Stick PRO Duo, which looks just like an SD card but measures just enough to not fit any reader. But this camera is old enough to have come with a USB card adapter. So I just pop the Memory Stick out of the camera and plug it into a USB stick. Then into my computer. Bingo pix and video ready for viewing , transferring or deleting. Not a high end item but it does have an articulating back, which I like for car shows.  :thumb:
