0 Members and 1 Guest are viewing this topic. Read 22599 times.
Question - what are the design challenges and limitations you have encountered so far.
John,Thank you for the answer to my question, but no need to be defensive with your response. I'm intrigued by your new/different approach to transducer design...not combative.Be well,Chris
John,Your speaker are dipole as regular cone drivers?Bipolar or elsemore?
I would think that you would have issues with "shear" strength in the long shaft. If played loud or under stress.https://en.wikipedia.org/wiki/Shear_strengthAnd I only mean that in the metallurgy sense of terms. Metal fatigue might be an issue after long periods of time. Have you tried any different alloys with the shaft material ?I know many machine/CNC shops don't know much about alloy/tool steels, because they most often use "hot rolled" steel, which is/are soft. There understanding of metallurgy is limited, in most cases.Good luck,V....
Th Planot driver is an omnidirectional radiator.John
So acoustic SPL will be low as all omnis or there is a way to increase it?
I'd think the farther it can rotate, and hence the size, the more SPL. Rotation distance would be like Xmax, and to increase it you'd be forced to enlarge the driver so the distance traveled increases at the outside...
Where do you get the idea that omnis are inherently low in SPL capability or even sensitivity, if that was what you are referring to?
John,As many here I would like to vote, but to so it is necessary to register and logon.Do you would have a direct link to the vote page?
My omnis knowledge is limited, I think omnis are low sensitivity as dipoles, not SPL capability.Do you would mention some hi sensitivity omnis?
I can think of two other true omni's;the German Physiks (BORDERLAND MK IV) and the MBL (Radialstrahler 101E).They both require a lot of power, my guess, because of the nature of the mass and stiffness of their designs and not because they are omnidirectional. (Please list any other true omnidirectional speakers/drivers you can think of. Don't include speakers that use reflectors or diffusers to smoosh the sound.)John
John, I saw this little teaser... https://www.youtube.com/watch?v=ZeGtdKoxk20I don't see any movement and from what I can gather, they are generating a fair bit of volume in that brief demo. This is truly exciting! You've obviously come up with something very original that is truly unique. Well done sir! I can hardly wait to see these developed into a commercial product. Having said that, I would not demo them without some bass augmentation. It's pretty hard to judge satellites without some bottom end.
