0 Members and 1 Guest are viewing this topic. Read 30877 times.
The amps do have the shelving circuit and they are playing down pretty low. Output wise and sound wise is really close to the H frame. Lots of pressure in the back of the wedge though. Two layers of MDF with braces is a must. I may add a few No Rez strips too just to see what effect it has. I need to try them in some different rooms too.
But I still do not know if and when the planar magnetic tweeters from Christy Digital will be made available again. So this whole kit is still on hold.
Sounds good.How did you wire up the divers, both from a phase standpoint and just physically making the connections? It looks like getting to the side of the drivers facing the front of the cabinet to solder the connections is going to be a challenge.
Will it be possible for the new planar magnetic tweeters you are looking at to be used in this kit either as is or with a baffle redesign?
No, they are really different.
All drivers are wired in phase. They have to be. All sensing coils are in series and all of the driver coils are in parallel. Wiring them up took some thought, but I figured out a good solution that is not too bad.
Danny,Do you have anything between the Wedgies and the bass units?
Okay, the bases worked out great. Here are some pics. Sorry for the bad lighting. I took the pics as they set in my listening room and not really set up for photographs.
Nice. What are the planar magnetic mid+tweet OB arrays with the 3x12 servos? Are those part of the (evolving?) Singularity for Serenity? Something for Mockingbird? Someone else? Or a future offering from GR Research?
Danny, when you say small to medium sized room, would that be about, say, 8 X 13 X 17 maximum or so?
Danny,Are the overall dimensions the same if 2x12s are used? Also, would the 2x12s be on the same side of the cabinet or opposite?Steven
Danny, will you be putting out plans and wiring diagrams for these?
Finished Serenity Acoustics product now on hold pending driver availability. They are the best sounding speakers that I have ever heard.
