0 Members and 1 Guest are viewing this topic. Read 16483 times.
You obviously haven't heard Nimbus, Derecho, Arcus, or Perfect Storm George, or you wouldn't have made that last statement. We had Nimbus running on a 3.5W 2A3 SET and a 35W 805AT SET at RMAF a couple years ago and it filled a very large conference room without a problem. And at Axpona 2014, we had Derecho running on 18W SET and were easily hitting 100dB in the room.https://www.youtube.com/watch?v=li-NBI6kP2IYour formula is of the form R || R/R. R/R has no units, so I'm not sure it's completely correct.Damping factor is simply the ratio of Zout and RL and it doesn't matter what class you're running.
pete i'm sorry i mentioned vapor speakers,what you do with them is your businessi'm out of this thread,you dont get my pointkind regards
ok Petei'll try my bestthere is always a dynamic resistance in parrallel with Rloadthis resistance is found by Vout / Ibleedthis has the tendancy to load the Zout and reduce the Vout abitand hence the dynamic impactwithout this resistance a class-b/ab amplifierthis only occurs with class-a not class-b/ab ampsthe Zout is constantbecause in class-a both semiconductors are always onis loaded only by Rload so you are correct and the damping factoris df= Rload/Zoutto put it another way if you load a certain source resistance with morecurrent there is gona be less voltage across the loadand less current into the load thus less dynamic impactthis is what happens with class-a there is this shunt dynamic resistancethat loads Zout and there is less voltage across Rloadkind regards
this only occurs with class-a not class-b/ab ampsthe Zout is constant because in class-a both semiconductors are always on
But don't forget crossovers, Steve.
I do not mean to but in, but this statement is not true. AB can easily have a constant or very near constant output impedance (Z). However, as the output approaches class B status, the output Z does vary with signal level. One needs to observe the plate resistance vs the plate current or grid voltage.CheersSteve
when it comes to tubes ampstwo things matter most1)good power supply2)good output transformerfor dynamic impact!these are not secret technologybut i'll mention here once againnfb does little for tubeslets start with transformersthe magnet wire thickness pri. sec.the transformer core sizethe winding methodnow power supplythe transformer va ratingthe filter caps sizethe power transformer voltageall these enhance the Zout capacity of the tube ampfeel free to disagreeThat's my understanding of this,please correct me if wrong
ha... to put it another way if frequency response is flat Zout is constant
So my first question is what happens if the input stage of an amplifier (uses no global negative feedback) and the input tube is, say a 12AX7 that drops the FR at some frequency X? The output stage itself can have a constant output impedance (Z) over the entire frequency range (at a given signal level), while the frequency response of the amp is not flat. I want to assume you meant just the output stage FR. Hope this helps.Steve
that's impossible!!!,the 12ax7 plate resistor is say constant,why? because is just a resistor (zout) and this resistor feeds another resistor (of the next stage imput z)unless it is loaded by the next stage imput z "which is impossible",there is nodrop at any frequency...
again,global nfb does little,the main reason is with tubes having less voltage gainscompared say to solid state,you can get away with local nfb howeveragain as Pete mentioned global nfb judiciously applied could be of some benefit.kind regards
Pete, et. al.,Sort of relevant to this thread, I guess I'll shill shamelessly for my audio blog, where I'm in the midst of a survey of SET-friendly speakers. Suggestions for additions to the list are welcome.Steve's Audio Blog
Depending on how much SET power is available . . .We had our Derecho model running on 18W SET power at Axpona in 2014.The Nimbus model was running on 3.5W and 35W SET power at RMAF in 2013 and 35W at Newport in 2013Perfect Storm and Arcus are also in that category due to rated sensitivity in the 93dB range.Even Joule ran exceedingly well on the 35W SET power we gave it with its 90dB sensitivity.
