0 Members and 1 Guest are viewing this topic. Read 6412 times.
Two possibilities.1. Can you move the speakers to alter that hump? What do other Magnepan 1.6 owners do about this problem?2. You might consider a Behringer DEQ2496, around $300 I think. Also 31 band dual Graphic EQ plus ten band dual Parametric EQ. It also has an ADC and DAC if you need it plus it is only XLR ins and outs. I use one for EQ just in digital and don't find it degrades the sound. I use it between my CD Transport and DAC. If you use it after your DAC it will need the Behringer to do an ADC/DAC conversion. When I used a turntable the phono amp went into the Behringer using its ADC, did its EQ in digital and went to my DAC. I thought it sounded pretty reasonable but others say, as you might expect, that the Behringer ADC and DAC are not the best and it's preferable to use it in digital only.
I have considered the Behringer Ultracurve DEQ2496 to use between my CD player and DAC via its digital optical inputs and outputs thereby bypassing the internal DAC of the Behringer but my concern is how do I hook up my usb out of my computer to the Behringer for computer music? I have also read some reviews of the Behringer introducing noise and being unreliable. Any thoughts on this?
Thanks for the offer. I have one here locally that I can buy used for $150.Magnepan 1.6's have a mid bass hump that the newer 1.7's don't have.
Is that Behringer a graphic or a parametric type.
